Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Is this possible?
  1. #11
    Mar 2006
    Colorado, but Canadian!
    have you tried in another OS? Windows may fail because of the weird drive formatting. I would burn a free knoppix disc and see if the drive registers. If it doesn't then try another mac. If that doesn't work, it is unreadable!!!
    1.9in x 2.9in -- 47mm x 73mm
  2. #12
    Apr 2005
    Queens, New York
    Where can i get knoppix
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
  3. #13
    Mar 2006
    Quote Originally Posted by Cheekz185 View Post
    http://www.knoppix.org/
    or just google for "knoppix live"
  4. #14
    Apr 2005
    Queens, New York
    thanks!
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
  5. #15
    Mar 2006
    no problem. Just burn the ISO file, stick it in, and it boots up to linux. No installation required. Stores everything on a RAMdrive too so it is like it was never even there.
    Every hac-.... err, I mean computer tech needs a copy!
  6. #16
    Apr 2005
    Queens, New York
    Ok so after i burn the iso and load linux what do I do from there? Just plug the drive in via usb? And maybe knoppix will read it?
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
  7. #17
    Mar 2006
    Well your best bet would be have it plugged in already either via USB or IDE. During it self install to the RAMdrive, it checks for any connected USB drives. If it finds any, it installs a driver that should work. Very user friendly for being linux. I was very impressed.
    Even has a GUI and everything! It shows up just like in windows with a drive picture called /dev/# where # is the number of the drive and you click it and it pops up an explorer-esque window where drag and drop is allowed.
    Pretty much like free windows. Well, legal free windows.
  8. #18
    Apr 2005
    Queens, New York
    So i got the Software Install CD from my friend and i started to MAC with the cd and the software install CD does not list the HDD so the HDD is not mounted!! I think the drive may be dead!
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
