Results 11 to 20 of 25
Thread: Verizon FiOS?
  1. #11
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    Quote Originally Posted by RickS View Post
    I've got FIOS and it is absoultely awesome. Definitely worth the $5/more per month over the DSL I had. True, there are few sources that can feed data as fast as I can consume it however, that's not really a bash against FIOS. It's really nice to pull files from Microsoft at 800K/s or three files at a time from Napster at 350K/s each.
    wait, are those the speeds your getting with FIOS? With the 30Mb connection?
    I get higher speeds then that all the time with my 15Mb connection. Maybe I won't switch after all.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
  2. #12
    Jul 2005
    Rosemount, MN
    Isn't a cable line shared (I mean the bandwidth ceiling)? Doesn't bandwidth fluctuate depending on users online at a given moment? I remember when cable first came out and then I remember my bandwidth plumiting towards the ground as it became more popular. Where are you guys getting 12mbps/15mbps from?
  3. #13
    Low Bitrate justin146's Avatar
    Feb 2001
    Oxford, MS
    Quote Originally Posted by digimotojoel View Post
    That whole 20mbps seems crazy to me. I was under the assumption, however, that the fiber actually required more repeaters then other solutions (this is coming from a code monkey though... what do I know). .
    The number of repeaters has to do with the technology they are using- if it is LED, then more repeaters will be needed, less with laser. Anything will be better than copper though.
    i know that a standard NIU for copper T1's weights about 20lbs and can support 4-6 T1's, whereas the QDFR's for our fiber is about the size of a cable modem and can support many times more data.
    Turbocharged 2000 Explorer 5.0 AWD, SCT tuning software, Carputer w/ Athlon XP2600 and 8" Lilliput custom molded into dash, Terk Commander XM, Rand McNally and MapPoint, bluetooth, and 802.11x
  4. #14
    Feb 2001
    Oxford, MS
    the cable where I live is fiber for long stretches, then splits off and modulates over coax. This makes their bandwidth ceiling higher. I am guessing that lots of older systems are still pure copper, so you would see bandwidth fluctuate more. It also is dependent on how much bandwidth the cable supplier has on their end- it could be bottlenecking at the cable company, not on the lines to your house.
  5. #15
    Low Bitrate RickS's Avatar
    Nov 2005
    Bethesda, MD
    Quote Originally Posted by Quattro View Post
    I've only got the 15Mb connection on FIOS (I think they wanted another $10 for the 30Mb and as we've heard, there's not a lot of reason for it). I've gotten higher than that but those are typical (especially from a torrent) but those are more typical of the higher end from a website. I wouldn't change from a 15Mb cable connection but that's not typical in itself...the best cable connection I ever had was 5Mb.
  6. #16
    Raw Wave lostreception's Avatar
    NY
    i have fios and i got this from speakeasy.net speedtest
    Download Speed: 9502 kbps (1187.8 KB/sec transfer rate)
    Upload Speed: 1827 kbps (228.4 KB/sec transfer rate)
    i dont really notice much of a difference between it and cablevision
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
  7. #17
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    Damm I get that with 6Mb cable. I'm happy with a 6mb connection with Comcraptic (Comcast)
  8. #18
    Dec 2003
    New York
    My cable company has fiber optic network, but then its coaxial to the homes.
    Quote Originally Posted by justin146 View Post
    Quote Originally Posted by lostreception View Post
    are you serious?
    I'm get more then that with optimum.
    This is with a wireless connection!
    Installed
  9. #19
    The Lavender Tie Just
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    Quote Originally Posted by durwood View Post
    You probably get 800kiloBIT/sec downloads, not kiloBYTE/sec....
    Rafster
  10. #20
    Variable Bitrate 84RegalRider's Avatar
    Nov 2004
    San Diego
    Download Speed: 6942 kbps (867.8 KB/sec transfer rate)
    Upload Speed: 548 kbps (68.5 KB/sec transfer rate)
    thats what i got with cox cable
    Core duo
    1tb harddrive
    256 ddr
    8 lilliput
    bu-353
    still installing...
  1. How to use your VERIZON cell for FREE internet
    By racerboy6996 in forum Wireless Communications
    Last Post: 05-30-2010, 06:20 PM
  2. Verizon wireless broadband and wifi phone
    By alinvegas in forum Wireless Communications
    Last Post: 02-23-2006, 09:46 PM
  3. Verizon Wireless cuts WiFi fees (59.99/mth)
    By mykolJay in forum Wireless Communications
    Last Post: 09-08-2005, 10:30 AM
  4. FREE Verizon PC5220 EVDO (take over contract)
    By abraverm in forum Classified Archive
    Last Post: 05-25-2005, 03:42 PM
  5. Garmin Etrex GPS & Verizon CDMA 1xRTT (PC3220) Wireless Card
    By mandiola in forum Classified Archive
    Last Post: 03-17-2004, 12:32 AM
