Results 1 to 9 of 9
Thread: brake light always on
    Feb 2007
    hi all im in need of some help, my peaugeot 206 has constantly got the brake lights on even when i hav'ent got my foot on the brake? what is causing this?
    thanks in advance
    Nov 2005
    UK
    lol. is that not a standard feature on pugs?
    i read the title and before i even clicked on the link to see what you wrote, i was expecting it to be about a peugeot!
    dont know what the problem is, just seen a fair few that way on the motorways etc. the first place i'd check would be the switch at the top of the brake pedal
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    I always thought it was becuase someone put a single filament bulb in a tail light, which would short the brake light circuit to the tail lights, but that would only cause the brake to be on when parking lights are on.
    Constant Bitrate mwmcginn's Avatar
    Dec 2006
    St Louis
    I would bet its a failure of the switch, but there may be an issue with the brake pedal return spring failing to return the pedal to the top where it would engage the switch.
    If you can pull the pedal to the top and it turns off the switch is alright, but if not you may need to replace or oil the mechanics of the switch.
    Mike M
    2006 Accord VP Sedan
    My worklog
    http://www.mp3car.com/vbulletin/work...-dads-car.html
    Constant Bitrate Vorex's Avatar
    Nov 2004
    Lake Worth, FL
    another thing to check that happens to 240's a lot is what the switch contacts to sense the brake pedal isn't being depressed. 240's have this little plastic mushroom thing, it's so cool, after a few years it deteriorates and falls out so you get out of your car one day and come back to a dead batt because the brake lights were on all night. Has happened to me twice, now I simply duct taped a quarter up in there, been like that for a year and a half with no problems ^_^
    - Vorex Out
    It's not really that small...No, seriously. judoGTI's Avatar
    Feb 2004
    Florida
    Yep sounds like a faulty brake light switch
    '02 GTI
    [Routis '04] [Opus 90W] [160GB Maxtor HD]
    [Lilliput 7" TS] [VIA M10000] [XMPCR]
    [512MB RAM] [Custom housing]
    [Deluo GPS Mouse] [E-MU 0404 Soundcard]
    Progress Meter: [==============|] 99.9%
    Feb 2007
    found the switch, it is located on the passengers side(for some strange reason) so i changedit now it works fine,thanks
    Nov 2005
    UK
    very strange. glad you got it sorted anyway!
    _
    Mar 2004
    Little Elm, Texas
    thread moved to ot...as it has nothing to do with CarPCs.
    Jan Bennett
  1. Replies: 22
    Last Post: 01-05-2006, 09:26 PM
  2. 16 led k.i.t.t fader brake light
    By Jcarere in forum General Hardware Discussion
    Last Post: 12-01-2005, 09:19 AM
  3. How many does it take
    By veedubya in forum Off Topic
    Last Post: 06-03-2005, 01:15 PM
  4. How Many Does It Take...
    By mp3z24 in forum Off Topic
    Last Post: 09-19-2004, 11:54 PM
  5. High Bright Sun Light Readable LCDs
    By PORTUGAL in forum LCD/Display
    Last Post: 06-23-2004, 12:19 PM
