Results 1 to 10 of 18
Thread: Embedded Navigation
    Variable Bitrate heezer7's Avatar
    May 2004
    IL, USA
    Embedded Navigation
    First off, our goal with OpenMobile is to have everything as integrated as possible without the use of external programs. We understand that you may already have a navigation program you have purchased and as a solution until we have more complete navigation offerings, this plugin will allow you to embed your existing navigation software. Here I just have it using Google Earth as an example. Coming in the .7 Release.
    Nov 2007
    First of all, I'm stoked to see OM progressing.
    But, i'd be happier if, when the GPS app is in the foreground, the only sign of OM was the back button in the lower-right corner, so that more of the screen can be dedicated to showing maps.
    Pretty please?
    Nov 2006
    Rubidoux, CA
    Does this Google Earth plugin work with the nav integration features in OM? Does it accept addresses from other sources, for instance? I'm at a loss for figuring, when moving from SD2, if I want to try the free Google Earth option, or the GMPC. I like the appearance of GE, but GMPC seems to be more 'integrated'.
    2000 Ford Expedition Eddie Bauer - Bi-Fuel Gasoline/CNG
    Intel D945GCLF2 w/512MB RAM, CL Audigy w/KxProject, M2-ATX, Lilliput EBY701
    Maximum Bitrate ws6vert's Avatar
    Sep 2008
    Baton Rouge
    heezer7 was just using Google Earth to illustrate the new application embedder plugin. This can be used to embed standalone navigation programs such as Destinator. There is currently no development for a Google Earth navigation plugin.
    Nov 2006
    Rubidoux, CA
    Quote Originally Posted by ws6vert View Post
    Ahh.. ok.. i read it as the google earth plugin was coming in the .7 release.
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Quote Originally Posted by CraziFuzzy View Post
    We're aiming a little higher with nav...but it probably wont be 0.7 that we get there
    May 2004
    IL, USA
    Yeah, sorry if I wasn't clear. This is just a temp solution to embed any nav software until we have more complete solutions ready.
    Maximum Bitrate jmullan99's Avatar
    Feb 2009
    Niagara Falls, Ontario
    GMPC using the embedded app plugin
    I just picked up my GMPC software today. Works a treat all by itself.
    Unfortunately, I am unable to get it functioning correctly using the embedded Nav plugin.
    It fires up fine, but then I am just left with a white rectangle. Sometimes I will see the opening screen with the two options (Where To, View Map) but when I make a selection I still end up with a white screen, the OM buttons (Home, Back, etc) are visible. Sometimes the white rectangle is higher up, so I cannot click Home.
    If anyone has any hints as to how to properly set things up so GMPC is embedded nicely please let me know.
    John
    PS: sorry for waking up an old thread.
    May 2004
    IL, USA
    In the settings for the plugin try moving the Delay slider to the right. That increases the time OM waits for the nav app to load and depending on the app/hardware can take a long time. It sounds like it is attempting to embed before it finished loading. The only app I have tested it on is Google Earth so may be an issue with embedding certain apps, but it should be ok.
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Also, keep in mind there is a GMPC plugin in development....just embedding it isn't the recommended way.
  1. New Russian GPS (Glosnass) available
    By MobiTekLink in forum GPS
    Last Post: 04-05-2007, 07:48 PM
  2. Need Testers for Mappoint embedded Navigation System
    By SilentAdmirer in forum V.O.I.C.E.S
    Last Post: 12-28-2006, 05:09 PM
