Results 1 to 7 of 7
Thread: Serial Amp Control Plugin
    Variable Bitrate heezer7's Avatar
    May 2004
    IL, USA
    Do you use a serial port and the DTR line to turn on your amps after boot up? No more messing with external programs or windows services. OM plugin is here.
    Maximum Bitrate jmullan99's Avatar
    Feb 2009
    Niagara Falls, Ontario
    I might like to make use of this. I am fortunate that my CarPC has one com port. But its in use by HD Radio.
    Will it work with a USB/RS232 adapter?
    John
    May 2004
    IL, USA
    Yup, I am using a USB adapter myself. As always your mileage my vary when using the adapters. Some of them just don't like to work. If you do some searching around you can find the various circuits you can use to do this. They are pretty simple.
    I also have updated this to be able to use either the DTR or RTS lines.
    Maximum Bitrate Borte's Avatar
    Jan 2006
    Norway
    Quote Originally Posted by jmullan99 View Post
    As long as the usb adapter exposes a com port in windows it should be good to go.
    Failure is not an option...
    __________________________________________________ ______________________________
    The only full multizone / multiscreen cross platform open source Front End -> OpenMobile
    Nov 2007
    It's my understanding that some of the cheaper USB-serial cables support only tx/rx and not DTR/RTS, etc. So, it's probably a good idea to stick with cables that have been proven to work, or that explicitly say they support the required signals.
    Feb 2009
    Good point.
    Maximum Bitrate customaudioman's Avatar
    Oct 2005
    My board only has (12)usb 2.0, firewire, esata and no serial. which is the best cable to get for DTR/RTS? brand cable?
    and also can you use one of these usb/serial adapters for hd radio or other modules?
  1. RRPDC - RoadRunner park distance control extension plugin
    By Robby BMW in forum RR Released Plugins
    Last Post: 10-03-2014, 11:38 AM
  2. Replies: 67
    Last Post: 02-14-2011, 11:55 PM
  3. Replies: 119
    Last Post: 12-25-2007, 03:20 PM
  4. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 09:26 PM
  5. Reproduction Control plugin doesn't work for ME
    By lifter in forum Software & Software Development
    Last Post: 07-09-2000, 10:41 PM
