Results 1 to 4 of 4
Thread: adding control after panel is loaded
    Jul 2010
    In response to the other thread I had, the last question was how to set properties/text/etc to a specific screen after the panel is already loaded. Since that has been answered, I have come up with a new question:
    How would I go about adding a control to the panel on a specific screen?
    Ex
    Code:
    //initialize has been run already and panel has been loaded already successfully
    private void button1click(OMControl sender, int screen)
          //add button dynamically to screen
          addtoscreen(screen);
    private void addtoscreen(int screen)
          OMImage picbox = New OMImage();
          picbox.Name = "NewPicbox"
          //add this to the screen that it was called from
          //tried:  p.addControl(((OMImage)manager[screen][picbox.Name]));
    But like what happened before it adds to the panel on a different screen other than the one I clicked it from. The above code didn't say any errors in the editor? Is it possible to add to a panel already loaded on a specific screen?
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Good Questions...the new website is going to have a code snippets database with snippets of code for lots of different tasks-so questions like this will be perfect.
    Code:
    //For plugins with only one panel:
    manager[screen].addControl(controlName);
    //For plugins with more then one panel:
    manager[screen,panelName].addControl(controlName);
    //And if adding more then one control-this may be easiest:
    OMPanel p=manager[screen,panelName];
    p.addControl(firstControl);
    p.addControl(secondControl);
    Jul 2010
    Cleared that right up, awesome. Here is another that might be worth asking/answering in terms of I can't figure it out but also for snippets...
    What's the equivalent of a new painteventhandler in OM, if there is one (to draw to the controls)? Normally you would use a new painteventhandler and capture the object and paintevent args. The actual new painteventhandler gives you acceess to the controls graphics object.
    I noticed that OM has a rendertext and renderparams, but can't figure out how they are used, if at all in this case of painting to controls.
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Quote Originally Posted by detlion1643 View Post
    The best way to do this (for a few reasons) would be to extend the control you need to do custom drawing on and override the Render method.
    Code:
    class MainMenuButton:OMButton
            public override void Render(OpenMobile.Graphics.Graphics g, renderingParams e)
                base.Render(g, e);
                g.DrawImage(icon.image, left + 48, top+18, 92, 92);
                if (ourTextTex == null)
                    ourTextTex = g.GenerateTextTexture(0, 0, width, 34, ourText, localFont, eTextFormat.Bold, Alignment.CenterCenter, Color.White, Color.Gray);
                g.DrawImage(ourTextTex, left, top + 112, width, 34);
    By doing it this way you can add custom properties, decide when or if the base control does its drawing and even have a re-usable component for other plugins or panels.
  1. The WinXPe Colab Installation instructions
    By darkslyde in forum WinNT Based
    Last Post: 02-17-2008, 05:59 PM
  2. Replace Civic 96-98 heater control panel with 99-00 panel
    By PredatorCoder in forum Fabrication
    Last Post: 04-24-2007, 05:14 PM
