Results 1 to 5 of 5
Thread: How to use OM's threading and paths
    lambosprit's Avatar
    Sep 2006
    UK
    I've read in the plugin guide lines that we should use the safethread or task manager classes instead of using threads but theres no mention of how to do this. So my question is should I and how?
    my code normally is
    Code:
            Dim workerThread As Threading.Thread
            workerThread = New Threading.Thread(AddressOf startup)
            workerThread.Priority = Threading.ThreadPriority.Normal
            workerThread.Start()
    The same question for paths. I want to follow the guidlines for paths but dont know how they work. For example I want to write out a debug log for my plugins and was after creating a OMSkype folder under plugins and create a log file , possibly a directory under that.
    lastly, is it possible to have a plugin directory? I have a number of dll's needed for Skype and it would be good to keep them all in the same place. I tried just creating it but that doesn't seem to work it only works if all the dll's are in the root plugin folder.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by lambosprit View Post
    One of the things I suggested right at the begininng.
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Even Easier:
    Code:
            OpenMobile.Threading.SafeThread.Asynchronous(AddressOf startup, theHost)
    Paths actually follow the official .Net specification, so its not even an OM thing, just something most programmers tend to not follow too well. The main rule is don't hardcode any paths or combine them yourself. Instead use Path.Combine to add the necessary path separators, but other then that its pretty straightforward.
    It should work as long as the folder name matches your dll name but i'll double check (ex Skype.dll in the plugins folder and SkypeSupport.dll in /plugins/Skype/).
    Quote Originally Posted by Enforcer View Post
    And we had added it before even suggested...it just wasn't released when you requested it. Anything constructive you want to add feel free
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by justchat_1 View Post
    Even Easier:
    Code:
    I thought thats what I was to use but what values to give. For example in combine what do I put for the openmobile path which I want to append to.
    My dll has the same name as the folder under the plugins path but it didn't work for me I'm afraid.
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Ah ok... The plugin host contains properties for the most common base paths. Theres SkinPath for the current skins folder, PluginPath for the plugins directory and DataPath for OMs data storage directory. The latter directory is a writable directory on every platform even win7 w/UAC.
    Alright then i'll add that to the TO DO list and make sure its fully working by the time your ready to release everything.
