Results 11 to 20 of 21
Thread: Developing an arduino shield - any interest?
  1. #11
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Quote Originally Posted by CyberBill View Post
    I'll have to look into the iTunes RR plugin - when I last looked around I could only find one project and it was not well supported and didn't seem to work.
    My PC interface is done in C# - I've actually got two programs. One interfaces with the arduino and the other is the front end to iTunes - there is a little bit of communication between the programs, and they're both written in C#.
    I'll see what I can do about posting the source up somewhere.
    You can use may be Mediafire or DRIVE or PM me and i give you my mail . I can send you a C# RR plugin example if you want !
  2. #12
    Nov 2011
    I really think my Arduino OBD-II adapter will be useful in this project.
  3. #13
    May 2008
    Bordeaux, France
    Quote Originally Posted by stanleyhuang View Post
    In fact !
  4. #14
    Dec 2011
    I don't have much experience with OBD-II, other than I've got a bluetooth OBD-II reader that I picked up on eBay for a few bucks, and it reads everything just fine. Is there additional info that can be pulled out of the OBD-II connector that it can't see (different protocol?) that the arduino versions can do?
  5. #15
    Nov 2011
    The OBD-II reading feature is nothing special. It just provides access to all PIDs that your car provides. The adapter provides power supply for Arduino unlike a Bluetooth or USB OBD-II reader. Also I spent time on developing and maintaining the Arduino library for this adapter.
    I am going to embed I2C accelerometer and gyro-meter in this adapter soon.
  6. #16
    Dec 2011
    So then why spend $60+ on building an arduino adapter if you can spend under $15 on eBay for a bluetooth USB adapter and a bluetooth OBD-II reader?
    It would make sense if you're not using a PC - and you want the arduino to actually read & react to messages or something, but if you've got the PC right there, it's going to save you a lot of time and money to use off the shelf components. I -hate- making my own stuff, and only do it when I've got a very compelling reason to do so.... or if I'm being stubborn.
    Heads up on doing i2c with arduino - make sure you are either using a 3.3v arduino pro, or pick up a 5v to 3.3v IO board, or be prepared to integrate that into your PCB. Most arduinos run at 5v and most i2c devices run at 3.3v, and the communication doesn't work between the two without logic level conversion. You can see in my PCB design that I have a logic level converter board plugged in.
  7. #17
    Nov 2011
    Yes I price my kit at $75, but that includes OBD-II adapter, an Arduino leonardo board, a SDHC breakout board, a 128x64 I2C OLED display module, as well as my efforts to develop the library and the sketch which are ready to use, and a free web service to render the recorded data into a nice chart. Can you get all these under $15 on eBay? Am I over-pricing? Also I am never forcing people to buy my kit. Everyone can just pick up my arduino library, use my chart rendering service, and make his own adapter.
  8. #18
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    That's a very good price Stanley for all that you are supplying. I know that setting up and getting everything working as it should is a big task let alone making the sketch too! Well done! SNO
  9. #19
    Nov 2011
    Thank you SNOtwistR!
  10. #20
    Dec 2011
    Yes I price my kit at $75, but that includes OBD-II adapter, an Arduino leonardo board, a SDHC breakout board, a 128x64 I2C OLED display module (which works at both 5V and 3.3V, really no sense to say most i2c devices run at 3.3V, regardless that most Arduino has 3.3v output), as well as my efforts to develop the library and the sketch which are ready to use, and a free web service to render the recorded data into a nice chart. Can you get all these under $15 on eBay? Am I over-pricing? Also I am never forcing people to buy my kit. Everyone can just pick up my arduino library, use my chart rendering service, and make his own adapter.
    The point of this thread is for me to get input on a kit that I'm making - so I'm just trying to determine if the goals of our projects are lined up well. I don't think your pricing is outrageous, that's just beside the point - your project has a different goal than mine. Mine requires a connection to a PC to be useful, and if that requirement is met, then integrating your project would increase my costs (time & money) by a substantial amount. I think your project sounds really interesting, and very useful for people, and for someone who needs that functionality it's a bargain over rolling their own.
    As far as the arduino and i2c are concerned, I looked around to try and find a nice 5v accelerometer and magnetometer in a DIP socket or on a breakout board without any luck. I ended up having to get 3.3v boards, and during testing they didn't work until I used the logic level conversion. I'm sure you can find 5v accelerometers & magnetometers, but the most popular ones out there are all 3.3v.
  1. OBDII Arduino Shield
    By bwallen in forum Hardware Development
    Last Post: 01-19-2015, 10:07 PM
  2. Arduino for OM - In progress
    By jmullan99 in forum OpenMobile
    Last Post: 03-13-2011, 05:43 PM
  3. Using Arduino to Auto-dim LED EBY701?
    By stevey500 in forum LCD/Display
    Last Post: 08-21-2010, 01:04 AM
  4. Arduino BT CarPC power controller
    By d_mc_a in forum Hardware Development
    Last Post: 03-18-2009, 10:20 PM
  5. Any interest in developing this skin?
    By tasq in forum FP Skins
    Last Post: 08-20-2007, 11:46 PM
