Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 47
Thread: New Skin Concept
  1. #11
    Apr 2011
    011100000110100001111000
    Quote Originally Posted by jmullan99
    The colors aren't my style, but that's another story.
    How about some suggestions? I am more than happy to make adjustments, especially if it takes us to a better looking skin.
    Wolfo
  2. #12
    Maximum Bitrate Borte's Avatar
    Jan 2006
    Norway
    I liked the original approach with the four corners better (but that's my personal taste), You can still cover more screens with that approach to. You could "slide" out an menu when the corresponding colored area is "long" clicked (ie. held). Doing this would allow for a far greater amount of screens, and it would open up for grouping of similar screens.
    Failure is not an option...
    __________________________________________________ ______________________________
    The only full multizone / multiscreen cross platform open source Front End -> OpenMobile
  3. #13
    Apr 2011
    Great point!!
    Quote Originally Posted by Borte
    personally i think I'd move the color indicator that indicates which screen you are at to both sides (top and bottom, not just top) to give off the effect of extending out from the button itself.
    Here are a few screen shots I worked on after Borte posted this. Thanks for helping!!
    Attachment 62030
    Attachment 62027
    Attachment 62026
    Attachment 62028
    Also updated the gif files for the wheels
    Attachment 62029
    and a new wheel for horizontal scrolling.
    Attachment 62031
    Please disregard the borders of the gif files. I can fix those later.
    Wolfo
  4. #14
    Apr 2011
    I am not sure where to take if from here. I think I have the concept and layouts finished. I have been reading and watching a lot of videos about c# and also have been looking at a lot of .cs files for the repository others have posted.
    Wolfo
  5. #15
    Jan 2006
    Norway
    Looks good!
    If you want to create a skin out of it you have to break your concept images down to separate pieces. Each item has it's own graphic in OM. It does not use the single image approach that RR uses.
    So each "menu button" (green, blue, red, purple) should have it's own separate images one for "highlight" state and one for "normal" state. These images should all be png with the proper transparency and other effect set properly. The same goes for your scrolling items. They have to be broken down into separate items.
  6. #16
    Apr 2011
    I made all of this in Gimp, so I have different layers for all of the color sections, highlights, backgrounds, etc. All animations are also setup in layers.
    Wolfo
  7. #17
    Jul 2010
    As I still understand it, the skinning tool hasn't been worked on in a long time, so it's a LOT of programming if you want a plugin or something to look/work different than it does on the default skin. At least the grunt work that interacts with the core of the framework can be used, but you're going to have to program all the user interactive parts yourself (at least for now). If you ever get stuck or need hints, help, or anything, the examples/repository are a great help, and we here will offer help too. The dev team helped me a bunch with trying to understand how to code to work with their framework, really helpful, great!
    EDIT: Great look so far, I like it being more colorful/stand out than the default. Keep at it!
  8. #18
    Maximum Bitrate jmullan99's Avatar
    Feb 2009
    Niagara Falls, Ontario
    Quote Originally Posted by wolfo View Post
    Wolfo
    Quote Originally Posted by Borte View Post
    I agree with Borte here. I like the colors and the wheel thing makes for many menu items.
    03 Cadillac CTS
    ZOTAC G43ITX-A-E 2.5ghz Core i3 2GB 160GB SSD
    Win7 Ultimate - OpenMobile - Directed HD - Wifi
    OMMaps + MS GPS Puck - WiFi via LTE Android phone
    2 Zones - Matrix Orbital LCD - Arduino - Build Pics
  9. #19
    Apr 2011
    Ok, here is the first concept screen based on a Radio FM selection. Not quite completed and would like some suggestions. I know to add the Artists name, current song, current song / total songs ratio, and progress bar.
    Attachment 62042
    What else should be added to this screen?
    Please comment.
    I am still not 100% sure where to start. I will take tonight and learn more about what OM resources are available to better understand what code needs to be written. But I am just shooting from the hip.
    Wolfo
  10. #20
    Jan 2008
    ^overall, i like it. it is relatively clean, and puts all the info right in front of the user.
    i am still not crazy about all the colors.. though i really can't think of a good suggestion to correct it-- i agree that the color helps separate the options, but it 'just don't look right'...
    something i don't see planned is a volume control. most users are going to need it(i use a external solution)--in terms of simplicity, that is one control that should need to stay in the same place for all selections.
  1. My First Skin Concept: Windows 7
    By ihateafropaul in forum RR Skins in Progress
    Last Post: 06-07-2010, 10:35 AM
  2. New Skin Concept- Like?
    By Sonicxtacy02 in forum RevFE
    Last Post: 06-08-2009, 06:55 PM
  3. Skin Concept
    By Simon123 in forum RR Skins
    Last Post: 09-03-2006, 07:14 AM
  4. Cameleon Skin [Concept]
    By JohnWPB in forum RR Skins
    Last Post: 08-24-2006, 09:53 AM
