Page 12 of 13 FirstFirst ... 2345678910111213 LastLast
Results 111 to 120 of 130
Thread: Android-ish Theme Request
  1. #111
    Jul 2010
    I vote for keeping the "Now Playing" info visible like this while in the music player mode. And actually in my Android this does display, just not at the same time as the track list. But your version works for me.
    Thanks! But I was more-so asking about the artist - songname and ratings displayed on the bottom bar, not the music plugin. So you can quickly see those instead of opening the notification bar everytime you want to see what's played...
    I've had a long night of trying to implement widgets, well at least what can act like widgets. I modified the main menu code so any plugin can send a string of controls to be added onto the screens on all the home screens. They start invisible, and only certain ones display when you select the widget to display. As of right now there are 2 areas designated on every home screen for widgets to displayed. Also, right now only images and labels can be accepted. Basically, the way it's set up right now, a widget is designed on the fly, so a plugin can change the look of their widget controls anytime they please. The code is just started and this is a rough implementation so far.
    I tried 1 attempt so far at trying to update the displayed widgets, and keep track of which ones are active, but I have to re-think that part of the design when I'm refreshed. For now, here's 2 screens with the same widget, but in the different spots.
    Current Worklog: TBA - '05 Rav4 (Mobo Dead).
    www.rav4world.com - Forums for Rav4 owners
    www.flavorfeasts.com - Cooking website/forums
    -Basic forums live atm, come contribute!
  2. #112
    Jul 2010
    Well, this is a sad update today...
    I cannot for the life of me figure out a workaround to get cross plugin/panel talk going. The whole ordeal of sending certain strings through theHost.sendMessage was completely scrapped and a new androidFunctions class was created and referenced. This had sendNotification and buildWidget functions which would fill 2 tables created in sqlite depending on the screen that passed in. Then, I threaded a poller for each screen for notifications, and again for widgets. The pollers constantly scan the tables for any plugins which had send data for a notification or widget.
    Upon changing all the code and implementing the new additions, it has taken a good amount of my time, and the end result isn't worth it. There is now slowdown in OM when there is data in the tables to be analyzed, ranging from 1 second to 5 seconds in my testing of playing music and switching panels...
    I realize that my first implementation of this is pretty rugged, as some timestamps or something to fire off a threaded event would work better than a constant poller. I have tried raising an event once and it ran on the same thread as other ui/mainmenu code, so it slowed the program down as well.
    At this time, I'm not sure what to do with the skin. I was trying to implement these as features of the android skin, to be used anywhere from any plugin if desired, but without them it just doesn't feature much different other than looks to the default skin. I'm well open to any suggestions!
  3. #113
    Maximum Bitrate Borte's Avatar
    Jan 2006
    Norway
    Is there anything I can assist with?
    Failure is not an option...
    __________________________________________________ ______________________________
    The only full multizone / multiscreen cross platform open source Front End -> OpenMobile
  4. #114
    Jul 2010
    Some new icons that I found for free, new text to know which home screen you are on, and new implementation of widgets with help/suggestions from Borte!
  5. #115
    Jan 2006
    Norway
    Great job! Looking forward to seeing it all up and running
  6. #116
    Jul 2010
    I've spent the past couple of days searching, and searching, and searching.... For some type of .Net compatible IMAP library. After much downloading sources, compiling them, decompiling other dll's, and piecing together samples of code I've yet to find anything to work, until tonight!
    Tonight I found a .Net library that was listed as free and could be distributed as compiled with NO restrictions. So I loaded up the example app, connected to my gmail account, and could navigate through my inbox or any other labels that I had set up. So I started piecing together what I could in my own test app, and I successfully created an app that can pull down all my emails from a folder/label. *I do not know about sending emails yet, but I know a simple smtp could be used for that*
    Given that, I started a new plugin to make use of this new library. Considering I have set up profiles already for the Music plugin to make use of, I have a design idea of allowing, at the start at least, a google account and password to be linked to the profile. Then, the new library will use the profile credentials supplied to populate the new gmail plugin.
    I'm pretty excited that I finally found a way to do this, and it's going to be a while before the plugin can be completed, but it's a very very good start!
    On the actual stuff I've been working at, the new implementation of widgets are performing well and there is no more slowdown noticed. I even created a simple clock widget that constantly runs and updates nonstop, and it didn't effect OM, so I am happy.
  7. #117
    Jul 2010
    Been a while since I've done an update here...
    Been slowly updating code to be compatible with all the new commits. Got most of the zone adding/editing stuff done and most of all the current code updated. Still mustering through some music code changes and smoothing out the skin overall.
    I've also spent a little time working with a new free 3rd party library for IMAP stuff. After I get the basic functionality down, I'll convert the look to join in with the default skin as well. So far, it just reads a folder/label, but it's smooth. Planned is checking for emails every so often and basic email sending. I don't think much else is needed in the car very a first version of the gmail plugin. Here is my mp3car folder loaded through the gmail plugin (can you tell what thread's been popular today lol)...
  8. #118
    Maximum Bitrate jmullan99's Avatar
    Feb 2009
    Niagara Falls, Ontario
    You're doing a fantastic job. Looking forward to playing with your final masterpiece!!
    03 Cadillac CTS
    ZOTAC G43ITX-A-E 2.5ghz Core i3 2GB 160GB SSD
    Win7 Ultimate - OpenMobile - Directed HD - Wifi
    OMMaps + MS GPS Puck - WiFi via LTE Android phone
    2 Zones - Matrix Orbital LCD - Arduino - Build Pics
  9. #119
    Mar 2006
    Why are you guys trying to reinvent the wheel just do a search for user interface at Graphic River and you will have more than enough options to mod http://graphicriver.net/search?utf8=...user+interface
  10. #120
    Jul 2010
    Re-invent what wheel? The graphics? I'm not, I'm not a graphical guy at all. I grabbed some free images/icons to use for the time being. Besides, that link/site all was about images or whatnot at $2 - $6...
    I don't have much to update since the last time, haven't done much on it really since, but I'm sure I'll get back into doing it and keeping at it after Easter (on vaca ).
    A little though: Basic smtp sending through gmail plugin is done.
  1. Product Request: Android 'Froyo' 2.2 - Large Novel, not for the weak hearted
    By Samsonite801 in forum Product Suggestions for the Mp3Car Store
    Last Post: 10-15-2010, 02:36 PM
  2. VW Theme (WIP)
    By _SYC_ in forum RR Skins
    Last Post: 05-29-2008, 10:57 AM
  3. Xp Theme
    By piyaca in forum CF Skins
    Last Post: 07-18-2006, 04:12 AM
  4. New Theme: CPX
    By marazi in forum NeoCar Media Center
    Last Post: 12-27-2005, 09:44 AM
  5. New THEME.INI available now :)
    By Marvin Hlavac in forum GPS
    Last Post: 10-31-2005, 01:50 AM
