Page 4 of 13 FirstFirst 12345678910111213 LastLast
Results 31 to 40 of 130
Thread: Android-ish Theme Request
  1. #31
    Sep 2007
    I'm still learning what OM can do If you can't control media player from home then leave that off. The other ideas sound good o me also.
  2. #32
    Maximum Bitrate Borte's Avatar
    Jan 2006
    Norway
    Media player can be controlled from any screen wit the media buttons (it's just a function of the layout of the screen)
    Failure is not an option...
    __________________________________________________ ______________________________
    The only full multizone / multiscreen cross platform open source Front End -> OpenMobile
  3. #33
    Jul 2010
    The question is more almost, what can't it do? If you haven't programmed in the environments then it can be tricky, but as a programmer, with full access to the .NET environment, plus all built in functions and controls in the OM framework, it's just a matter of using the right code. Plus wrapped opengl functions (I think opentk it resembles) - man, I wish knew opengl/graphics .
    I ask because, like Android, that media box can be a "widget" that is updatable by the media player plugin. However, updatable (live) menu items is not something OM can do right now.
    I don't want to overstep or sound arrogant here, but why not? Can the main menu not perform the same mediafunctions (mediastates? can't remember exactly) that the default ui.dll had in them. States that update via song change, play, etc? If it can, just update the right labels on the main menu?
    So I would think (for now) we can leave that off the menu pages, scroll "now playing" stuff in the top bar , and when top bar is swiped down you get the media player page.
    As said before, the top bar looks small. I did find gesture code in the ui stuff, but haven't really looked at it yet. Will there be enough room to swipe inside the top bar? Or are you implying if you only start the swipe in the top bar?
    Andrew's idea of the volume knob in the bottom corner with the behavior you mention works for me. A couple media buttons on the bottom bar (prev/next, play/pause) or, like the default skin, press a single button to bring up media controls. Maybe, as long as there is media playing, the bottom bar shows media buttons?
    I'll plan a horizontal sliding volume bar (basically horizontal design of the default vertical one for now) for testing. It can always be changed later. As for media controls, is there enough incentive to offer the full range of them? IE) ff,rw,stop? There might be enough room on the bottom bar to fit prev/play(pause)/next buttons since those are prob the most use. The other media buttons could be used in the media screen? Is this an ok idea?
    Current Worklog: TBA - '05 Rav4 (Mobo Dead).
    www.rav4world.com - Forums for Rav4 owners
    www.flavorfeasts.com - Cooking website/forums
    -Basic forums live atm, come contribute!
  4. #34
    Sep 2007
    Sounds good to me I'm not that picky on the fine details. Just let me know if you need any new images for the home screen.
  5. #35
    Maximum Bitrate jmullan99's Avatar
    Feb 2009
    Niagara Falls
    Quote Originally Posted by detlion1643 View Post
    I have every faith that it could be programmed as part of the Main Menu plugin. You would have to account for the placement of menu items sort of auto-wrapping around it. I don't know if you are familiar with Android so excuse me if this is obvious (I also am not trying to sound superior in any way) but when the user picks what apps (plugins) to add to the home screen (main menu), the main menu needs to arrange them, including the widgets (the media box) no?
    What I am thinking is the idea of 'widgets' for the media box that Andrew proposed. A widget is user place-able. Almost a stand-alone mini application that can be placed on any of the main menu pages. As most know, I'm not a great OM plugin programmer :O but when I think out the way these things would work, it would mean a whole new category of plugin and the way the Main Menu behaves. I was just not sure it was doable at this point. But if you're confident that it can be done, by all means go nuts it would be an excellent feature.
    I was thinking if the gesture started in the top bar (again, like Android behavior) like you are dragging down the top bar like a drawer.
    I have no preference to vertical or horizontal volume. I do like the +/- being available when the volume is tucked away. But that's just my preference. I have the CharacterLCD plugin with Matrix Orbital and I assign volume buttons to that so makes it always available as well.
    My personal thought on the basics you mention (prev/play(pause)/next) are all that are needed on a regular basis. At least from a driver point of view. If you are on the main menu you are likely trying to get to a different app (nav?) otherwise you may well leave the full media screen visible. I'm not sure how crowded the bottom bar will get :S.
    On a side note, I know it's media player related, but I like the behavior of "Previous" to first jump to the begining of the current track, then, if a second press occurs within a second or two, it will jump to the previous track. That way, if I wish to hear the current song again, I can. Current behavior (while in shuffle mode) jumps to a random track (not the previous track) so I cannot easily navigate back to the same song
    Okay, I fear I have rambled enough
    Cheers,
    John
    ZOTAC G43ITX-A-E 2.5ghz Dual Core Celeron 2GB 160GB SSD
    Win7 Ultimate - Remote Starter - Directed HD - Wifi
    Garmin Mobile + MS GPS Puck - LTE WiFi Hotspot
    2 Zones - Matrix Orbital LCD - Arduino - Build Pics
  6. #36
    Feb 2009
    Niagara Falls
    Quote Originally Posted by andrewfblack View Post
    Oh, I am sure as this moves along, you will get a few requests for more images! Especially for "icons" for main menu for other plugins. I'll need one for Arduino. I "want" to flesh out the guts for some OBDII plugin, just the basics. We'll see how far I get once I grab an ELM327 interface. An ambitious little project for me, but what the heck.
    John
  7. #37
    Jul 2010
    With everything that is being discussed - I'm gonna say the bottom bar is too crowded.. I say this because if we talk about volume/play/next/prev that's already 4 less places for buttons to be configured to go to plugins. If we add the +/- to volume as well, I think it starts taking up too much room.
    For swiping the top bar, at this time to me it's a little small - If we want to up the height/pixels from the current to maybe about 70 or so, it will just be that much more manageable. Then we could keep the volume stuff in the top bar. But that's probably gonna negate the reason to swipe in the top bar..
    Easy enough to do!
    I have no clue how Android works. I've seen it, but never used it myself. I do know that if you add an app, the main screen can grow so that you can scroll up/down to see them all. Do we want the main menu screen to house the apps as well? If not, maybe I can build a horizontal scrolling control (think the lists but with horizontal flick movement) that sits on the ui level. The one that doesn't scroll is the home button - all others are listed too scroll, so you can just 'scroll' to the plugin you would like... I'm just throwing out ideas, as I said I have no idea how Android works, but if we are just trying to keep plugin buttons available from anywhere....
    I'm actually going to stop suggesting ideas at this time... You know Android better than me, the more I suggest, the less Android it's probably gonna resemble.
    Oh boy! I seem to be rambling now
  8. #38
    Jul 2010
    I hate to double post, but I don't feel this is just edit worthy...
    I did a quick look into Android 4.0 (heh, though they were still on 2.x if that shows you how I don't know much about it). They came a long way from what I used to know.
    Looks like they now have a 'bottom' bar that includes common apps to be launched. We can make something like user configurable common plugins. They can choose like 3-4 and those chosen can be included on the bottom bar. Maybe all other plugins would be vertically scrolled like Android's main home screen?
    Looks like the top bar in Android is just notification stuff.
    Widgets placeable/sizeable on the main menu. The main menu, as it might house other apps, could be split into 2 sections. Widget section and app section. Think like left 1/2 of the screen could house configurable widgets, and right 1/2 of screen could house the scrollable apps?
    Other than these 3 things - Most changes are under the hood or things that I am not programming for. Camera's, editing photo's/videos, network control, multitasking...
    Wait, multitasking? New to me on a phone anyways. Is there enough to warrant coding multitasking. It would be a huge pain keeping track of everything panel wise from plugin-to-plugin, but it could be done with enough time. Default OM can be used like 80% multitasking, it only screws up when using multiple panels in a plugin, otherwise the original panel state stays as it was. I don't see a need for multitasking-switching plugins, but others might...
    This still brings about the volume/media button problem of before, where to put these? The left side of the bottom bar is probably the best place (since right side could house the common plugins)?
    Alright, this time for real, you guys tell me how this skin should work with resemblance to Android. All I have is viewing of screenshots/info from Androids website...
  9. #39
    Jan 2006
    Norway
    Quote Originally Posted by jmullan99 View Post
    Oh, I am sure as this moves along, you will get a few requests for more images! Especially for "icons" for main menu for other plugins. I'll need one for Arduino.John
    Icons can be generated on the fly from font's in OM or assigned a picture. There is a special attribute for this if you look at the top of each plugin code you'll see it. This is how the icons for the main menu is assigned now.
  10. #40
    Jan 2006
    Norway
    OM already multitasks... It's a question about how your plugin is designed. If you reset everything each time the panel is shown then it will not multitask, if you keep your own thread running and don't reset anything then it will multitask. OM does not shutdown or kill any plugins unless the plugin crashes or OM is closing.
  1. Product Request: Android 'Froyo' 2.2 - Large Novel, not for the weak hearted
    By Samsonite801 in forum Product Suggestions for the Mp3Car Store
    Last Post: 10-15-2010, 01:36 PM
  2. VW Theme (WIP)
    By _SYC_ in forum RR Skins
    Last Post: 05-29-2008, 09:57 AM
  3. Xp Theme
    By piyaca in forum CF Skins
    Last Post: 07-18-2006, 03:12 AM
  4. New Theme: CPX
    By marazi in forum NeoCar Media Center
    Last Post: 12-27-2005, 08:44 AM
  5. New THEME.INI available now :)
    By Marvin Hlavac in forum GPS
    Last Post: 10-31-2005, 12:50 AM
