Results 1 to 5 of 5
Thread: Carbon Shiftgate
    Jan 2013
    Carbon Shiftgate
    I have an idea for a basic shiftgate styled theme with a shifter knob as a volume slider and/or button-press indicator. The top right corner could have a preview window for album art or whatever. The thought is when you press a button, the shift knob would go to the slot in the gate temporarily, then back to its original location along the volume slider.
    Name:  Carbon Fiber Gate.jpg
    Open to ideas or suggestions if you have any. We can make any of the images you want, we just can't do the %&^*($ coding!
    PSD file is attached. Carbon Fiber Gate.psd
    Jan 2013
    Slider coding
    What is the possibility of adding animation to a button or control? The goal is to have the chrome shift knob move into position when you hover/click on an icon, but have the knob double as the volume control slider. How would we animate the knob to move into position, or automatically hide the volume slider when the buttons are highlighted?
    Screencap:
    Maximum Bitrate jmullan99's Avatar
    Feb 2009
    Niagara Falls
    Hi! Glad to see folks still monitoring us
    Animated controls (or animation/graphics) are one of the big things that has been worked on in OpenMobile. And most of the work is handled by the framework. It is much easier for folks to create plugins.
    I do not know when there will be a new commit to the SVN. But in short, the answer will be yes to your question(s) about animated controls.
    As for "how" to do it, I can't properly answer. I am the tester, although I have made myself a plugin. Somewhere along the way somebody (probably Boorte) will post a reply and give a little more heads-up.
    ZOTAC G43ITX-A-E 2.5ghz Dual Core Celeron 2GB 160GB SSD
    Win7 Ultimate - Remote Starter - Directed HD - Wifi
    Garmin Mobile + MS GPS Puck - LTE WiFi Hotspot
    2 Zones - Matrix Orbital LCD - Arduino - Build Pics
    Maximum Bitrate Borte's Avatar
    Jan 2006
    Norway
    Quote Originally Posted by Azothyran View Post
    You can animate any property on a object in OM. So making it slide along the gear shift pattern is really easy. All that is needed is to use the smoothAnimator class and have the smoothAnimator change the left and top properties on an image based.
    Failure is not an option...
    __________________________________________________ ______________________________
    The only full multizone / multiscreen cross platform open source Front End -> OpenMobile
    Jul 2010
    To make a skin takes knowledge in C#/VB as of right now... With that though, essentially anything inside the framework or .NET will be useable. I don't have much free time these days to help out with the programming aspect, but we're all here to help if you need it.
    Current Worklog: TBA - '05 Rav4 (Mobo Dead).
    www.rav4world.com - Forums for Rav4 owners
    www.flavorfeasts.com - Cooking website/forums
    -Basic forums live atm, come contribute!
  1. Carbon Fiber Fabrication help
    By 74z28camaro in forum Fabrication
    Last Post: 03-20-2012, 12:39 AM
  2. carbon fiber sub box
    By stkdidy ntshidy in forum Fabrication
    Last Post: 08-12-2006, 04:59 PM
  3. Need Carbon Fiber
    By Tred in forum Fabrication
    Last Post: 01-27-2005, 09:19 PM
  4. carbon fiber
    By djXternal in forum Fabrication
    Last Post: 07-07-2004, 05:55 PM
  5. carbon skin
    By liquid_smoke in forum ME Archive
    Last Post: 01-13-2004, 03:22 AM
