Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: High CPU Load after Install
    Jan 2007
    Columbus, OH
    When I was bench testing the CarPc, the cpu load was around 40-50% but then I added a wifi adapter and installed in the car and now the cpu load stays between 98-100%. My memory is 73% free. I turned off some more of the services but that's when it dropped to 99%. It was running a consistent 100%. Any ideas?
    Mar 2006
    Colorado, but Canadian!
    Roadrunner being used? If so, then do you have the correct flash version for it (8 not 9)? Have you checked the "high cpu load with RR" thread?
    If not roadrunner, then the frontend and list of apps running while this happens would be nice.
    1.9in x 2.9in -- 47mm x 73mm
    Jan 2007
    Columbus, OH
    I actually read that first thing this morning and was considering giving it a try, even though I use a different skin. I use the Digital FX skin, will doing the forced downgrade really make a difference?
    Mar 2006
    Quote Originally Posted by mdlesk View Post
    forced downgrade of flash?
    Yes it will.
    The thing is flash 9 uses some new way of displaying flash files. Legacy files meaning not 9 when tried to be played on a 9 system, have to be emulated or "swished" I believe the flash term is. I am not sure on the term, but it basically is running your flash in an emulator.
    So if you go to a native flash 8 system, and try to play flash 8 files all the way back to 4 I think, you are fine. You cant play files encoded in flash 9 at all. And flash 4 and lower files are emulated, but you have to search high and low to find anything in flash 4 or lower.
    So basically yes it makes a difference. On epia boards, it can make the difference between running smoothly, and running choppily and freezing. On a system with a dedicated gpu, then it will just emulate it there, and it should be a negligable gain in performance, but it still will help.
    Jan 2007
    Columbus, OH
    Okay, thanks. It's worth a shot either way. I am working right now, but when I get home I will try it.
    Mar 2006
    work?!
    Work is for suckers! Just ask our belgian friend IC-C30
    j/k buddy.
    FLAC XC-C30's Avatar
    Jun 2006
    Abele, Belgium
    Quote Originally Posted by 2k1Toaster View Post
    work?!
    j/k buddy.
    Are you sure you still want to visit Paris nick? be sure I don't track you down then
    Xenia & Isabelle, totally in love!
    'T SQiekenkot: VOLVO 740GL 2.3
    CarPC: none at the moment
    CLARION HX-D2
    CLARION APA4300HX => Fountek NeoCd1.0 + TB W4-1337SD
    CLARION APA4300HX => CSS Trio8
    CLARION APA2100 => Dayton IB385-8
    Mar 2006
    Quote Originally Posted by IC-C30 View Post
    And how will you find me? Talk dutch to the parisians?!
    I can just ask them if they found a weird belgian wondering around mumbling under his breath about a badger, and go the other direction!
    Jun 2006
    Abele, Belgium
    did you know I like hunting? And I don't care if it is hunting-season or not
    CLARION HX-D2
    Jan 2007
    Columbus, OH
    I just tried it and guess what, it worse. The CPU is now a constant 100%!!! It did go down to 99% for a brief second, but went right backup. I don't know what to do. I am running RoadRunner, Wifi, Bluetooth, phonecontrol.net, Iguidance with Pharos GPS-360, and the recommended version of Winamp. I downloaded the replacement OCX flash file and renamed it flash9b.ocx since my other file was named flash9b. *UPDATE* After a fresh reboot it is down quite a bit now so it must have worked. But it still needs some work done. I'm now around 90% using Digital FX Skin. It is the same with the original skin. My goal was to be able to play music videos, but right now that seems impossible. Does anyone have ideas on what I can do?
  1. Why can't I install windows XP ? please help ?
    By shinjetko in forum Newbie
    Last Post: 09-19-2006, 03:02 PM
  2. Jagputer Install and story log
    By JagPuter in forum Show off your project
    Last Post: 08-02-2006, 09:48 PM
  3. Tinyxp vs nlite vs sensible install
    By geeky_hawkes in forum WinNT Based
    Last Post: 06-15-2006, 04:55 PM
  4. How should i install this?
    By jnusaira in forum General MP3Car Discussion
    Last Post: 08-13-2004, 04:03 PM
  5. High Bright Sun Light Readable LCDs
    By PORTUGAL in forum LCD/Display
    Last Post: 06-23-2004, 12:19 PM
