Results 11 to 20 of 25
Thread: Hibernation problem...
  1. #11
    Mar 2007
    columbus
    i have the same problem. took system in the house and could not get it to duplicate. put back in the car, motherf***er does it again. i have noticed if i manually select hibernate, the problem is less likely to happen.
  2. #12
    Variable Bitrate walstib's Avatar
    Jul 2005
    Atlanta, GA
    I think this may be more of a USB problem. Stiv & PeterD0404, are your GPS units plugged into a USB hub or directly to the mobo?
    Carputer Project Status:
    0% - Mobo died on 2/17/08
    Check out the worklog for my '01 Pathfinder.
  3. #13
    Jun 2007
    MA
    Walstib,
    My GPS is a CF card plugged into a CFto PCMCIA converter. I was thinking of removing that and using a USB card reader instead.
  4. #14
    Jul 2005
    Atlanta, GA
    Hmmm. I was thinking it may be a timing issue. USB is not getting power before OS tries to see it. Same could be true for CF coming out of hibernation. I would think CF would always have power when cold booting, in case that is where the boot image lived. Not sure.
  5. #15
    Nov 2005
    Penang
    I am having exactly same issue with this, even already reformat my hdd and re-setup XP SP2, also having the same problem. my mobo is Jetway J7F2WE1G5D coupled with M2, after a thorough read thru the thread, probably is the mobo bios issue, and I just downloaded a updated copy of firmware, hopefully can solve. i will reply once i have the updates
  6. #16
    Nov 2005
    Penang
    just done the upgrade for my jetway J7F2WE1G5D BIOS, from Version A08 to A10. But it's doesnt help much, and return the same error. Need to looks for other solution now. Maybe swapping another setup between hdd, mobo..etc..
  7. #17
    Jun 2007
    MA
    I agree with Walstib.. I think it's a timing issue. Lucky8, When does this happens? what devices do you have that currently turned on?
  8. #18
    Jun 2007
    MA
    I'm looking to get a bluetooth GPS receiver, I think this will fix my problem. I haven't done any research as of late. Is there anything better than Sirf III?
  9. #19
    Elsewhere
    Quote Originally Posted by PeterD0404 View Post
    I'm willing to bet that the bluetooth GPS would make this more of a hassle, since Windoze is going to have to deal with the bluetooth connection when it goes into hibernation.
    Here are a couple of other questions I have about your hibernation issues:
    1 - How much freespace is there on the HDD? There needs to be enough free space to be able to write HIBERFIL.SYS
    2 - Could the power supply be cutting power too soon? The PC may not finish writing the system state to HIBERFIL.SYS and cut power prematurely, leaving you with a corrupt hibernation file.
    How about the Wiki?
  10. #20
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    My SP13000 keeps randomly rebooting whilst trying to install XP Pro on a SATA HD.
    Just found out I need to add SATA drivers by F6'ing on the first setup screen
  1. Opus 150 problem coming back from hibernation...
    By Sal R. in forum Power Supplies
    Last Post: 01-10-2008, 04:20 AM
  2. Replies: 11
    Last Post: 06-19-2006, 05:10 PM
  3. Problem with hibernation
    By tratpop in forum General Hardware Discussion
    Last Post: 02-27-2006, 06:38 PM
  4. Bluetooth problem and hibernation
    By ThEScReW in forum Map Monkey
    Last Post: 02-05-2006, 04:29 PM
  5. Xenarc 1040 POS hibernation problem
    By Vinister in forum LCD/Display
    Last Post: 04-24-2005, 12:33 PM
