Results 1 to 2 of 2
Thread: Media drive on EWF system
    Jul 2006
    When using EWF to protect a CF card, do you choose which drive you are protecting? If you have a seperate hard drive for media can you still save to that normally or do you have to type in the commands to disable EWF?
    I ask because I want to use centrafuse so if I add music to my hard drive (media drive) do I need to include the commands to disable EWF or no? I don't want to write unneccessarily to my CF drive but still want to be able to update media easily and within centrafuse + be able to save playlists.
    Low Bitrate erie's Avatar
    May 2006
    The XPe based I built for my work I have the D: drive unlocked for user profiles, temp drive and application installs. Not sure if using ewf on a XP would be any different, but I dont think so.
    You are able to only lock a single drive or all the drives, just change the commands pramaters.
    the ewf commands are: ewfmgr <drive-letter> -enable
    06 Galaxy Gray Si #0308
    CarPc Progress -
  1. Hard drive shock / vibration thoughts
    By S11D336B in forum General Hardware Discussion
    Last Post: 09-27-2006, 12:40 AM
  2. MB870 & Slimline Floppy Drives
    By McGreggor in forum General Hardware Discussion
    Last Post: 11-09-2005, 07:32 AM
  3. Beyond Media out tomorrow!!!
    By Defiler in forum Software & Software Development
    Last Post: 12-04-2004, 02:27 AM
  4. P90 system: Use HD manager? (for 20GB drive)
    By Tony S in forum General Hardware Discussion
    Last Post: 04-19-2001, 01:59 PM
