Results 1 to 7 of 7
Thread: xp messages at startup
    Mar 2007
    How do I get rid of the warning balloon that says "you don't have an antivirus installed".
    is this in msconfig under startup tab? and if so, what is it called?
    it's annoying because it will display over top of Road Runner.
    thankyou
    Mar 2006
    Colorado, but Canadian!
    when the popup occurs, click the baloon, and look on the left for "change how xp notifies me".
    1.9in x 2.9in -- 47mm x 73mm
    Nov 2006
    click start, go to run, type services.msc and hit ok. scroll down to security center and double click it. change automatic to disabled, hit stop, then exit out. you're done
    Mar 2007
    thanks guys, it worked.
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    To Disable The Notification Area Balloon Tips
    Warning If you use Registry Editor incorrectly, you may cause serious problems that may require you to reinstall your operating system. Microsoft cannot guarantee that you can solve problems that result from using Registry Editor incorrectly. Use Registry Editor at your own risk.1. Click Start, click Run, type regedit, and then press ENTER.
    2. Navigate to the following subkey:
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced
    3. Right-click the right pane, create a new DWORD value, and then name it EnableBalloonTips.
    4. Double-click this new entry, and then give it a hexadecimal value of 0.
    5. Quit Registry Editor. Log off Windows, and then log back on.
    Cut and pasted from the Microsoft website
    New Age Garmin - Skin for RR
    Aug 2006
    West Allis, WI
    Also here a is quick script that will make all the necessary edits.
    If you do not feel comfortable with using regedit.
    http://www.dougknox.com/xp/scripts_d...alloontips.htm
  1. XP taking longer and longer to boot!! Why?!
    By 1RyanRs in forum WinNT Based
    Last Post: 06-30-2007, 11:17 AM
  2. Software Review: Windows XP Media Center 2005 Edition!
    By nFiniteTuning in forum The Review Palace
    Last Post: 05-01-2007, 11:54 AM
  3. Another crazy mod: RAM booting XP (no, not EWF)
    By SFiorito in forum WinNT Based
    Last Post: 01-18-2007, 07:39 PM
  4. Can I upgrade XP home to prefoessional?
    By Skipjacks in forum Software & Software Development
    Last Post: 01-30-2005, 08:06 AM
  5. annoying XP spam messages
    By RaZor in forum Off Topic
    Last Post: 12-14-2004, 08:41 PM
