Results 1 to 9 of 9
Thread: Booting from CF
    Aug 2006
    Booting from CF
    OK, I've exhausted all of my options and now I'm tired of seeing my efforts fail, so I'm hoping someone can find a solution.
    I know a lot of you use a CF card for your OS because the CF card is more stable than most drives. My only problem is how to get it on there.
    I have installed the OS onto a laptop hard drive and optimized it. I prepared the CF card by using fdisk, format, and bootprep while booting into DOS. I encounter a problem when trying to copy the files over. When I try to use my DOS disk to copy, I can't seem to get a partition set to the location of the files on the laptop drive, thus I can't utilize the features of xcopy. When I try it with another OS on a separate computer, the xcopy command locks my computer up and does not allow me to do it. When I attach both of the drives to my carpc and use the xcopy feature, I get sharing violations and files in use.
    So, now I'm in a pickle. I've thought I had it working once only to find that I get numerous disk errors when I try to boot the OS from it. I assume that this could be caused by not actually having all of the necessary files, but the error I get when I try to boot reads:
    Disk Error
    Press any key to Restart
    DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER
    Also, I know this will make some of you guys have chills down your spine, but I tried simply installing my nlite-d XP onto the CF card with the installation cd. I thought it would work--it completed the installation, but the I got the same error.
    For those who it may help, I am using a 4GB Transcend x266 Compact Flash card with a CF-to-IDE converter.
    Please, if someone can help, I would really appreciate it. It's my last step in installing my new, upgraded PC and I'm racking my brain for options, but I can't seem to get anywhere.
    Thank you for any help!
    CT
    FLAC SFiorito's Avatar
    May 2004
    try copying the files using a BartPE boot disc
    Aug 2006
    How can I designate a partition for the laptop drive? I tried using a bootdisk to copy and that was the trouble I encountered.
    May 2004
    have you used BartPE? that is a CD bootable Windows XP OS.
    Aug 2006
    Ohh, I used BartPE's DOS disk. I'll give that a try and let you know how I make out.
    Thanks for the suggestion!
    Aug 2006
    I didn't think about it until I did it, but the problem with that is that both of my IDE slots are taken up by my CF-IDE and my laptop drive. The BartPE program for XP creates an iso to burn onto a CD.
    With both of my IDE slots taken, I can't connect my CD drive and, therefore, can't boot off of a CD.
    May 2004
    oh, that sucks....you don't have a USB enclosure for the laptop drive or a USB CD drive do you?
    Aug 2006
    Unfortunately, no. I might could borrow my friend's, but I'll have to see about that.
    Any other ideas? I tried the XP Boot Floppy disk he has on that site and it just seemed to redirect me to the hard drives.
    Maximum Bitrate crooper's Avatar
    Nov 2006
    Everett, WA
    Can't you use a regular 2-plug (master/slave) IDE cable for your laptop drive and your CD drive? I think the laptop drive has to be master...
    I used Norton Ghost on Hiren's Boot CD to copy to my CF.
  1. Formatting and Booting CF Card
    By ambush276 in forum WinNT Based
    Last Post: 07-19-2007, 10:53 PM
  2. booting from CF card slower than HDD, disappointed. what's wrong?
    By mattress in forum General Hardware Discussion
    Last Post: 08-25-2006, 01:11 PM
  3. Problems booting from CF card
    By dcdc in forum Operating System Optimization
    Last Post: 01-16-2006, 06:10 PM
  4. So Who's booting from CF???
    By RoyN in forum WinNT Based
    Last Post: 09-13-2005, 09:56 PM
  5. XP Pro on CF card working!!
    By knubile in forum WinNT Based
    Last Post: 01-03-2005, 06:48 PM
