Results 1 to 5 of 5
Thread: HELP....Car PC self hibernates!
    HJC
    HJC is offline
    Apr 2007
    California
    Hello all,
    I got a carPC that goes into hibernation on it's own after 5 minutes only in this certain situation:
    -When I have music on PAUSE.
    AND
    -Only after coming out from hibernation. If it's a fresh restart it stays on indefinetly.
    AND
    -Only when Road Runner is running. If I exit out to the Desktop, it also stays on indefinetly.
    System specs:
    Intel D201GLY "Little Valley"
    1GB Ram
    80GB Fujitsu HD
    BU353 GPS
    Lilliput 7" touchscreen
    RR version 12/06/07
    Winamp 5.13
    WinXP Media Center 2005
    Power settings in XP are set to Always ON.
    I can tell it's not a wireing issue cuz it stays on if music is playing or during a fresh restart. Any advice on where to start checking?
    Constant Bitrate krnpimpsta's Avatar
    Dec 2007
    DC Metro area
    Hmm.. one possibility is that it's going into hibernation when your CPU is drawing alot of current, causing the voltage at the power supply to drop below the threshold, initiating shutdown/hibernation. Can you try doing something very CPU and/or GPU intensive to see if you can cause it to shutdown? Maybe by running a 3d game?
    If that causes hibernation/shutdown, then I would look into:
    1) finding a better ground
    2) upgrading power and ground wires to thicker gauge wires
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by krnpimpsta View Post
    That is a good idea, but those little valley ones are like the via systems, really low power. You cant really overload an available DC-DC with one of them unless you try!
    I wouild look at your power settings just to make sure. The whole inactivity for x minutes, does blah, and turn off the monitor in y minutes and all that. I know you say they are ok, but they can get reset sometimes without knowing.
    If those are fine, then do you have a USB keyboard or something with a hibernate key? You could be getting your signals crossed somewhere, and the computer is picking up the signal for the GPS lets say, and interpretting it as if it were a keyboard, and hibernating it. I would find this unlikely, but a possibility, even more so since you say if you are at the desktop nothing happens.
    What RR skin are you using? If you use the default BMV2 skin, does the same thing happen?
    1.9in x 2.9in -- 47mm x 73mm
    HJC
    HJC is offline
    Apr 2007
    California
    Quote Originally Posted by 2k1Toaster View Post
    Thanks for the tips guys. I'll try running the default skin to see if anything happens.
    HJC
    HJC is offline
    Apr 2007
    California
    problem solved
    If anyone needs to know what happened for reference.
    Set in rr.ini:
    hibernateaware=false
    Problem solved.
    Guess RR does some funny stuff in the background after a few hibernates. This only happened for my particular motherboard, mentioned above. When I had a old Compaq Presario in the carPC, I did not have this problem.
    Thanks to those who tried to help.
  1. In a real PC car struggle
    By markland556 in forum Off Topic
    Last Post: 06-27-2007, 11:36 AM
  2. New to Car PC, here is my setup.
    By BarinaHum in forum Newbie
    Last Post: 11-06-2006, 08:16 PM
  3. First install of car pc working :)
    By optip in forum General Hardware Discussion
    Last Post: 09-09-2006, 07:13 PM
