Results 1 to 10 of 12
Thread: HORM help please
    Nov 2006
    Arizona
    HORM help please
    I just installed EWF and it is working great, I then added the "horm.dat" file to my root drive. When I hibernate windows goes into hibernation fine, but then when i trun the computer back on it starts normaly... If i remove the "horm.dat" file hibernation works fine, but once that file is in my root drive then hibernation stops working. If i type in the command "ewfmgr C: -activateHORM" or "ewfmgr C: -DeactivateHORM" I get a response "Failed to get HORM state".
    I've been searching all night and i cant find anything so i .
    Thank you for the help!!
    2001 Camaro SS #2070
    Maximum Bitrate Kimota's Avatar
    Nov 2006
    Fort Lauderdale ,Florida
    Hi CoryF
    Make sure you are using the horm.dat file extracted from the XPeSP2FeaturePack2007.iso found here http://www.microsoft.com/downloads/d...displaylang=en
    I'm pretty sure you've already seen it but follow the directions found here http://granturing.blogspot.com/
    Ohh your in luck here are the extracted files I'm using Ewf-Horm files.zip
    Hmmm just had a thought if you already have EWF up and running and attempting to copy the horm.dat file to the root of C: while EWF is enabled the change would not be saved when you reboot as EWF was enabled.
    Just in case make sure you disable EWF by running "ewfmgr c: -commitanddisable –live" then copy the horm.dat to the root of C:
    Renable EWF with the "ewfmgr c: -enable" command then reboot check and make sure the horm.dat is in the root of C: after the reboot, hibernate then restart hopefully horm should be working for you
    Good luck.
    P.S
    I suggest you make two .bat files one to disable EWF and the other to Enable EWF they come in handy when making changes.
    Nov 2006
    Arizona
    Okay i'll try that. I created my own horm.dat so i'm sure that replacing this file will fix the problem.
    The .bat files are a GREAT idea!! Much much much much faster.
    I have:
    One for the status
    One to commit and disable live
    and One to enable and reboot
    First time ever making a .bat file but i think they will do the job.
    I'm making a CD with the files right now, I'll post back and tell how it goes.
    THANKS FOR THE HELP!!!
    Nov 2006
    You don't have to make a cd if you have winrar open the winrar console and just extract the files. You could also use the files in my zip.
    Let me know if it works
    Nov 2006
    Arizona
    Works Perfect! The time that it takes for windows to log off and go into the hibernation screen is a long time... Is this normal?
    Nov 2006
    Hmm I never had that issue might depend on your system. You could try defraging then running bootvis
    Nov 2006
    Arizona
    Hibernation times went back to normal once i removed the extra *.dll's from my system32 folder that I had added from your zip file. Bootvis says that it only takes 1.15 seconds!!! But that is with nothing running, and only a mouse, keyboard, monitor plugged in. I cant wait to load up RR and see what my boot times are going to be!
    Nov 2007
    for HORM to work, do i actually have to have EWF working?
    while i do have a CF/IDE stuff, its sitting in a drawer on my desk, and i'd just as soon not use it, but i'd love to be able to still use HORM with out disabling the ability to write to the drive
    1997 Chevy Tahoe
    Planning 30%
    Installation 15%
    Overall Progress 12%
    worklog
    FLAC SFiorito's Avatar
    May 2004
    yes, you must use EWF to use HORM
    EWF, HORM, MinLogon on XP.
    Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
    Win Embedded Std 2011 RC
    OCZ Vertex Turbo 30GB SSD
    Lilliput 629 Transflective, WRX Screen Mount
    BlueSoleil BT, i-Blue GM-2 GPS, DirectedHD Radio, Andrea Mic
    VoomPC 2
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    But does EWF have to actually be active though?
  1. HORM without EWF
    By FX35 in forum WinNT Based
    Last Post: 04-22-2008, 08:53 AM
  2. HORM and RR : How does it work ?
    By Konrad in forum Road Runner
    Last Post: 01-23-2008, 08:29 AM
  3. Question about SD and HORM
    By Snoobaru in forum StreetDeck
    Last Post: 09-04-2006, 10:49 PM
  4. Horm
    By lez in forum WinNT Based
    Last Post: 07-07-2006, 07:38 AM
  5. Minlogon, EWF and HORM - Problem Fuzzy screen menus after HORM hibernate
    By ruairi in forum Operating System Optimization
    Last Post: 11-30-2005, 08:51 AM
