There is another command you should probably try first to see if it fixes (System File Check). Repair overwrites your current windows and if I remember right, really messes with your installed programs...
"start", "run", then type
SFC /scannow
try that and see if it fixes everything.
Silly question, but can you not restore back to before the drivers were installed? Once you get everything working right, I would suggest getting "Norton Ghost" and create an image of your setup. Then no matter what happens, you can always go back to that point.
LinkBack URL
About LinkBacks
