Results 1 to 10 of 16
Thread: Hibernation Tab gone?
    Constant Bitrate overlander's Avatar
    Feb 2008
    Question Hibernation Tab gone?
    I'm using Windows XP home on a Jetway C7J5, and I just did a full reinstall. In my initial install, my power options had the hibernation tab in the power options. Now it doesn't. I didn't change anything in the BIOS between the reimage, and I don't know where to look to try and reinable the option.
    Any ideas?
    Constant Bitrate b3tts32's Avatar
    May 2006
    Arlington, Tx
    Usually that happens when the driver for your video card isn't installed.. check your device manager to make sure you don't have anything in your "other devices" tab
    Feb 2008
    Thanks. I have not reinstalled my video driver yet, so that must be the culprit.
    P.S. Your avatar is nasty.
    Feb 2008
    That was it. Loaded video drivers, and tab showed up. Thanks.
    May 2006
    Arlington, Tx
    Yeah no problem
    SD beats everything. So there. danielkh's Avatar
    Sep 2007
    Beaverton, Oregon, United States
    Future reference.....if you only have standby, turn off, and restart, hit the shift key while it's displayed. Standby becomes Hibernate. Didn't notice that before SP3.
    My opinion is my own.
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    53
    for future reference others problems could be acpi bein disabled in the bios and the enable hibernation check is disabled in the control panel power options.
    Live mp3Car Facebook Chat
    Nov 2005
    Bringing this thread back from the dead since it addresses my problem, no hibernation tab.....
    I re-installed XP Pro on my CarPC and noticed that the Hibernation tab was gone. I followed the guidance in this thread by using the CD that came with my Lilliput monitor (Touchkit) but I still don't have the hibernation tab. The touchscreen is working fine (and did before I installed the Touchkit program w/drivers). What am I missing? The first time I loaded XP Pro on this computer a long time ago the hibernation tab was always there.
    May 2006
    Arlington, Tx
    Touchkit drivers don't have anything to do with your hibernation. You should look to make sure your display drivers are installed. To do that you just need to look in your device manager. Control panel > system > hardware > device manager. Then you will probably see something in other devices or double check display adapters.
    Nov 2005
    Quote Originally Posted by b3tts32 View Post
    Yeah, I knew the touchkit drivers were for the touchscreen portion of the monitor, but it was the only CD that came with my monitor so I was "hoping" it also had video drivers. As far as the device manager is concerned, I looked there and did not see any "other devices" or "display devices" (which I remember seeing before in the past). That tells me that I am using the "generic" video driver (so I can see something), but since I did not see anything in the Device Manager, I am not sure where to look now.
  1. Skin: Blue Tab
    By gold28 in forum RR Skins
    Last Post: 03-13-2008, 05:05 AM
  2. hibernation tab missing
    By amk136 in forum General Hardware Discussion
    Last Post: 01-30-2008, 04:39 PM
  3. 5 minutes to complete hibernation? WTF?
    By DRWeside in forum General Hardware Discussion
    Last Post: 03-12-2006, 10:36 PM
  4. Enabling Hibernation TAB
    By Peoples in forum WinNT Based
    Last Post: 03-17-2005, 12:48 AM
  5. Hibernation Tab gone after reinstall
    By GReeToZ in forum General MP3Car Discussion
    Last Post: 01-07-2005, 01:37 PM
