Results 1 to 10 of 12
Thread: Windows Resume Loader
    Jun 2005
    I get the following message on my CarPC (running Vista) if I turn off the PC while resuming from Hibernate (like moving my car from the driveway to curb):
    Windows XP seemed to always use the first option. It never prompts you with a menu. Is there anyway to turn this menu off? Or suppress the message by specifying a default value?
    Variable Bitrate Jistari's Avatar
    Dec 2007
    New York
    The easiest way to circumvent this and other problems with poweron, power off is to just put a simple three pole switch on the white accessory lead that wakes your PC up.
    You have three wires running to the PC, ex. red (constant power), black (ground) and white (accessory) power (only on when ignition on).
    Run the white wire from your accessory power to the top leg of the switch.
    Run a red wire from the constant 12V power to the bottom leg of the switch.
    Run a white wire from the middle leg of the switch to the white wire going into your PC.
    With the switch in the top position, PC works as it does now, starts and shuts down when power on accessory is seen.
    With the switch in the middle position, PC doesnt start. This is where you put it to just start the car and move it.
    With the switch in the bottom position, the PC will stay on and running even if you shut the engine. Good for quick stops when you dont want to go through a whole shutdown/wake up from hibernation.
    The switch also acts as a reset switch for when the PC hangs or something doesnt initialize right, switch to middle position will cut power to the white line and the psu will do a shutdown, flip it back to top position and it will wake up.
    PDP1170/TRS80/Atari800XL/Amiga500/286/486/P2/P4/C2D still a newb (but an old newb, been doing this a while) working my way up to "Complete Newb"
    Nov 2005
    Bump - exactly what I wanna know!
    Wish you could bypass this, or have it atleast timeout after a certain time.
    Jun 2005
    Ok I finally figured out the problem which prevented the computer from staying in standby (forcing me to use hibernate). I knew that the problem was caused by my touch screen controller (Xenarc 700TSV). I tried to disable the USB Root Hubs from bringing the computer out of standby within Device Manager. This had no effect on the problem.
    Today, I came across the solution; a command line executable which gives you fine control over your power settings (Vista only). Below are the commands I ran to fix the issue:
    1. powercfg -DEVICEQUERY wake_armed
    The command above will list all the devices on your computer which will bring it out of standby. In my case the following device was the only one listed:
    "USB Touchscreen Controller(Universal)"
    I then ran the next command to actually prevent the device from waking the computer:
    2. powercfg -DEVICEDISABLEWAKE "USB Touchscreen Controller(Universal)"
    The end result is that my computer now stays in sleep mode and I am able to hibernate it after a certain period of time to save my battery (I have it set to 60 minutes currently). I am hoping this works around the issue and helps anyone else out there.
    Nov 2007
    Thanks for posting the solution!
    Jun 2005
    Just tested to see if Microsoft changed this menu in Windows 7. They haven't . I really would like to set a timeout on the menu or better yet disable it.
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    Quote Originally Posted by JWise1203 View Post
    Looking for a solution aswell
    Aug 2010
    Large Windows Desktop Icons
    In Windows XP, icons are 32x32 by default. However, icons are provided in 48x48 format, and some even larger. In Windows 98, there was a box you could check off to accomplish this easily. However, it is not as intuitive in Windows XP as in Windows 98.
    _________________________________
    Want to get-on Google's first page and loads of traffic to your website? Hire a SEO Specialist from Ocean Groups seo pecialist
    Feb 2010
    Any solution for windows 7? to somehow force Windows to always choose: "Delete restoration data and proceed to system boot menu" ?
    Maximum Bitrate kegobeer's Avatar
    Nov 2010
    Panama City Beach
    I don't know of a way, but you might check out sevenforums.com. Maybe someone over there knows how, if it's even possible.
  1. Ahhhhh Windows Can Blow Royally
    By Sidewalksalvage in forum Off Topic
    Last Post: 01-25-2007, 02:17 PM
  2. Replies: 7
    Last Post: 10-19-2006, 07:34 PM
  3. Windows ME and MediaCar
    By dug1967 in forum MediaCar
    Last Post: 04-15-2004, 02:30 PM
  4. A few observations in OS and why I'm now using Windows 2003...
    By Mastiff in forum Software & Software Development
    Last Post: 01-21-2004, 10:11 AM
  5. Fast Boot/Fast Resume for the Windows Platform
    By dbinnc in forum Software & Software Development
    Last Post: 10-19-2001, 09:39 AM
