Results 11 to 20 of 23
Thread: So What Is The Fastest Boot Up Time I Can Expect............??
  1. #11
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    Hibernation doesn't require ANY power. Nothing needs to be maintained. Windows writes the resume data to a file. You should be able to hibernate the computer, unplug it, take it to another location, plug it back in and resume right were you left off.
  2. #12
    Sep 2008
    Even when setting the system to hard off after 45 seconds, the compute will still draing the battery. I have mine to hard off after 45 seconds and using hibernation, and if I leave my for a week without using it, the battery will be drained. For daily driving and up to 3-4 days of non use, it's fine though.
    Even with hibernation, the boot time for that board is really slow though. If you want a good fast boot, go with the Jetway 1.5GHz. From hibernation to playing music is about 15 seconds.
  3. #13
    FLAC SFiorito's Avatar
    May 2004
    does that board keep power to USB constantly?
    EWF, HORM, MinLogon on XP.
    Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
    Win Embedded Std 2011 RC
    OCZ Vertex Turbo 30GB SSD
    Lilliput 629 Transflective, WRX Screen Mount
    BlueSoleil BT, i-Blue GM-2 GPS, DirectedHD Radio, Andrea Mic
    VoomPC 2
  4. #14
    Sep 2008
    I don't know.
  5. #15
    Constant Bitrate bl3nd3r's Avatar
    Jun 2006
    Pickering, Ontario, Canada
    I have also had the problem with an m2-atx killing a battery when I use hibernation. It seems that with my system however, hibernation doesn't actually work and it seems to get stuck at the stage where the power should be cutoff.
    I wonder if it is just a bad m2-atx or if there is something else wrong.
  6. #16
    Nov 2005
    Quote Originally Posted by fabworks View Post
    Well that is not the way it is supposed to work, at least not according to the M1/2-ATX instructions. When HARDOFF is set, it is supposed to cut power completely. The M1/2-ATX doesn't wake up again until it sees the ignition signal when you turn on the car. The M1/2-ATX does not require any type of "standby power" to sense the ignition signal.
    It sounds like you may have another device in your car that is draining your battery and/or your battery is damaged and slowly failing.
  7. #17
    Variable Bitrate Bimmerstyle's Avatar
    Sep 2006
    Belgium
    Quote Originally Posted by jmciver View Post
    I think so too. Or you have another device that's draining your battery or you have a bad power suply (something is wrong with it) or your battery really needs to be replaced. When "Hardoff" is enabled the PSU isn't supose to drain anymore power.
    BMW 525tds -Biostar I94GM-I4 -Celeron M44O 1,86GHz, M2-ATX, 1Gb, 320GB -HQCT RDS tuner -Creative Extigy -iBus controller -Lilliput 7" touchscreen -DLS Ultimate A7 amplifier -Focal 130K, 130V, 27V2 speakers
    Bezel Worklog-My Install -iDrive F01 RR Skin
  8. #18
    Sep 2008
    Well, you guys give it a try to see if it works. Leave your car using hibernation for a full week and you'll see. I know that the power supply is supposed to work that way, but it doesn't. I have a new battery and have used diff. power supplies.
  9. #19
    Jun 2007
    I've done it several times without a problem. But I'm using a Carnetix P-2140.
  10. #20
    Variable Bitrate Jistari's Avatar
    Dec 2007
    New York
    In my old setup (Jetway MB with Pico psu, and MSI MB with Pico PSU) I parked the car for days with no problem.
    Now I have an Intel D945GCLF2 and an M2 ATX and when I parked it down at the shore for three days, the battery wasa dead when I went to start it.
    Always use hibernate, never used suspend.
    Im not arguing with anyone who says that a computer when hibernated does not require any power, Ive taken it out of the car many times, it boots back up no problem.
    But thats not what we are talking about here. What we are talking about is that in some configurations, if you leave the pc in hibernate, you may have a dead battery when you come back after several days.
    I guess it depends on the car, the electrical system, the MB and the PSU.
    Im pretty sure if you put a small light bulb at the end of 1000 feet of wire hooked up to your battery with a switch, even if you left the switch off, your battery would be drained after a few days. I have no idea how or why (not an electrical engeneer or anything) but some things just put a draw on the system.
    At any rate, mine never went dead before the M2, and its going dead now, so . . .
    I'll rewire it so that if I'm leaving the car for a few days I'll be able to completely cut the constant and acc lines to the pc.
    PDP1170/TRS80/Atari800XL/Amiga500/286/486/P2/P4/C2D still a newb (but an old newb, been doing this a while) working my way up to "Complete Newb"
  1. Media Player Error
    By Autockr989 in forum StreetDeck
    Last Post: 02-25-2008, 11:14 AM
  2. Replies: 2
    Last Post: 01-31-2008, 03:15 AM
  3. Oh where have all the Shutdown Controllers gone (and boot time)?
    By SuperAJ in forum General Hardware Discussion
    Last Post: 05-21-2005, 10:57 PM
