Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: So What Is The Fastest Boot Up Time I Can Expect............??
  1. #21
    Sep 2008
    When this happened I was using the Via SP13000 motherboard. I left the car at a shop for an entire week and when they went to start it up, it was dead.
    It would survive 3-4 days at the most. Now I'm using the Jetway 1.5GHz board, but have yet to test this and I'm not interested in doing so either . I have left it over the weekend and it's fine. I don't know what causes this, but it does happen. I'm using the M2-ATX as well. I know it's not supposed to, but it does.
  2. #22
    Apr 2008
    Ballarat, Australia
    Hibernating itself uses no power at all. All of the RAM contents are written to the hard drive then read back in on the next boot.
    The problem could be that some motherboards keep external devices powered constantly. A common one is the keyboard and mouse (this is so that the computer can be started by using a keyboard/mouse button rather than the case button). Have a look at the BIOS and there might be a setting like "Keyboard Power-On" or similar.
    Otherwise you might just have to install a timed relay switch which actually cuts power after the car is stopped. Or a flip-switch would do it (except you would have to flip it every time to use the carPC).
    2004 HSV Clubsport M6
    Gear:Zotac ION mobo, Voom2 case
    Progress: [||||| ] 50% - Planning done,
  3. #23
    Variable Bitrate bemenaker's Avatar
    Nov 2008
    Not a hibernation problem
    Hibernation uses zero power, only standby on PC's requires power. If you are draining your battery down, something else is pulling power. Your pwer supply my not be going to zero drain or something else is staying powered up.
  1. Media Player Error
    By Autockr989 in forum StreetDeck
    Last Post: 02-25-2008, 10:14 AM
  2. Replies: 2
    Last Post: 01-31-2008, 02:15 AM
  3. Oh where have all the Shutdown Controllers gone (and boot time)?
    By SuperAJ in forum General Hardware Discussion
    Last Post: 05-21-2005, 09:57 PM
