Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 35
Thread: i am not getting any help on this....
  1. #11
    Dec 2007
    understood 2k1Toaster. it's cereron 900 mhz. with 1 gig Ram. I don't have anything other than RR, bluthtooth, and a few common prog running on it.
  2. #12
    FLAC WuNgUn's Avatar
    Sep 2007
    Maybe some services optimization might be in order?
    Have you checked your event logs? I'm sure you'll find something not right logging as an error or warning...
  3. #13
    Mar 2006
    Colorado, but Canadian!
    XP I am guessing?
    Well a 900Mhz machine isnt going to blow shutdown times out of the water to begin with. Only thing I can see is bluetooth that could be causing a problem. Bluetooth in general is processor intensive with a bad stack and when connected to a device, it needs to disconnect before shutdown. uninstall bluetooth and see if it helps. But honestly, 30 seconds on a 900mhz celeron isnt bad at all.
    1.9in x 2.9in -- 47mm x 73mm
  4. #14
    Oct 2008
    try this registry edit.
    values in milliseconds. Set the WaitToKill options to smaller values if you like.
    [HKEY_CURRENT_USER\Control Panel\Desktop]
    "ForegroundLockTimeout"=dword:00000000
    "HungAppTimeout"="4000"
    "MenuShowDelay"="200"
    "WaitToKillAppTimeout"="5000"
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l]
    "WaitToKillServiceTimeout"="5000"
  5. #15
    Dec 2007
    thanks for the tips guys... just about tried everthing you've suggested... Didn't help a bit.. uninstalled blutooth... tweak the registry... Followed 100 steps to optimize xp... etc.... Non helped... By the way, i misinformed you about 30 sec. shutdown time.. it's 1min 30 sec... I am about to do a fresh reinstall of XP, and go from there.. Maybe 1min 30sec is normal for 900ghz system?
  6. #16
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    I would hope a 900ghz system would take significantly less time to shut down... :P
    I've had desktops do that where all of a sudden the shutdown time gets really long, I usually wind up just dealing with it until the next reformat. Haven't found a real solution yet.
  7. #17
    Dec 2007
    it turned out it can do a lot better than 1min 30sec..
    since i have no way or knowledge of installing xp from cd or any external drive with my umpc, i was researching for a way to do it with usb thumb.. Then i came across this ghost file which looks to be like a striped ver. of XP with sp3. Installed it. Bam... 5 sec shutdown... But, i tell you it's missing some things... i couldn't install blutooth app... don't know what else it might not allow... but you know what.. who cares.. rr runs and i have 5sec shutdown.. i am back to happy now
  8. #18
    Sep 2007
    Ever thought about using hibernation, like the rest of us?
  9. #19
    Dec 2007
    yes.. i would love to do that, but my battery is completely dead... i might need to get a new one but it's a bit expensive...
  10. #20
    Jul 2006
    Hibernation doesn't use any power, standby does
    MSI K9N6GM
    1 gig RAM
    8" Lilliput
    Onstar GPS mod
    XM
    Visteon HDZ300
