Try unplugging all USB devices then test the shutdown speed...
If it changes for better: likely some usb driver/software is your problem -- in this case, plug one by one USB device and shutdown in between each device you plug ... time each shutdown and see what the cost (in time) of each device is.
If you see no changes: You likely have some service running that is taking some time to shutdown... you can try disabling any services you don't need and/or opening device manager and disable any device you don't use. There's also a registry setting to set how long a service/application has (in seconds) to terminate after a shutdown request -- reducing this amount can help a lot in some cases.
LinkBack URL
About LinkBacks
