Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: xp optimization with nlite
  1. #11
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    I'd get roughly a 10 to 15 second boot time with an nLited version of server 2003, no swap file, 512mb ram, and using EWF. Not bad for an 800mhz machine.
    Tidder
    Try RevFE
  2. #12
    Variable Bitrate dMand's Avatar
    Oct 2007
    The Evergreen State, Washington
    Quote Originally Posted by Tidder View Post
    That's too fast, I need a few more seconds in the morning to warm up the car.
  3. #13
    FLAC WuNgUn's Avatar
    Sep 2007
    Ha!!!
  4. #14
    Mar 2006
    Blog Entries
    1
    I noticed no difference with hibernate when I switched from full version of XP to a stripped down version of XP. I'm only using 512MB of ram to keep the hibernate file small.
  5. #15
    Mar 2009
    ok, u know if a zotac 610i support this feature?
  6. #16
    Elsewhere
    Most motherboards have this feature.
    To be 100% certain, I'd check out the motherboard's user manual and see what it says about options available int he BIOS setup.
    That should give you a clue.
    How about the Wiki?
  7. #17
    Sep 2003
    New Mexico, USA
    Quote Originally Posted by BlackStealth View Post
    Yeah, there really should be no difference. What makes a difference is hibernation speeds is ram size of course, and system/ram speed. All you're doing is dumping the entire contents of ram to your hdd. How you've optimized windows will not matter.
    Tidder
    Try RevFE
  1. Replies: 1158
    Last Post: 04-06-2011, 10:38 AM
  2. Safe nLite setting.ini
    By IntellaWorks in forum WinNT Based
    Last Post: 02-03-2010, 06:41 AM
  3. nLite XP ? and performance
    By NJ_Jackals in forum WinNT Based
    Last Post: 10-13-2008, 02:53 AM
  4. Problems with touch drivers in xp pro (nlite)
    By mind3 in forum WinNT Based
    Last Post: 06-30-2008, 02:58 PM
  5. Replies: 7
    Last Post: 10-19-2006, 07:34 PM
