well someone might prove me wrong, but i did not notice any difference when resuming from hibernate, i think this is because when resuming from hibernate windows does not use the boot.ini file, but i could be wrong.
HiJackX1 UAMCB w/ The Tobiathin Core Android/Win 7 hybrid system!
4x 10inch Tablet
1x Win 7 / Rear Entertainment PC
ft/ Web Server Streaming
Sorry about posting a couple of months later, but I have to correct you guys.
Changing the numproc doesn't do anything. Windows uses all the cores all the times.
#2 http://lifehacker.com/5033518/debunk...tweaking-myths
Also the /maxmem tag i think is also incorrect. Windows be default uses all RAM. /maxmem is used if want only a certain amount a RAM used.
Andrew
That is correct to a point. Most all settings in msconfig are not really for tweaking, more for troubleshooting/limiting purposes. The numproc is used to limit how many CPU cores Windows will use, comes in handy sometimes since some software (like SQL 2005) requires cores to be in multiples of 2. Also can test programs against different numbers of cores for dev purposes.
Same with /maxmem. It is indeed used for limiting windows usable memory from what's available. In my carPC I use a /maxmem=384 setting to decrease my resume from hibernation times even though I have a 2gb Ram stick in there.Also the /maxmem tag i think is also incorrect. Windows be default uses all RAM. /maxmem is used if want only a certain amount a RAM used.
Andrew
However I do disagree with what that lifehacker article says about disabling services. Disabling services will have a HUGE impact on boot times. Look at how fast an optimized version of Micro2003 boots vs a standard XP install.
Hey guys - the delay entry in boot.ini doesn't have anything with a single OS boot unfortunately - it is how long the multi-boot OS list is present for, until the top one is chosen. Thats if you have more than 1 os on your system.![]()
