Page 1 of 5 12345 LastLast
Results 1 to 10 of 42
Thread: Which OS should i use?
    Oct 2006
    Hey ppl,
    So i am building a new car pc, here is the spec:
    32GB SSD Hard Drive
    Jetway mini-itx motherboard
    INTELŽAtom Dual-Core 330 CPU (45nm,FSB 533MHz,1.6GHz,1MB L2 Cache)
    2GB DDR2 RAM
    So i am wondering which version of Windows to install.
    I will be using either Road Runner or Centrafuse.
    USB:
    Touchscreen
    BU353 GPS
    USB Audio Converter Thingy
    I have heard that win2k can give some amazing boot up times and i would like to keep boot times small, i think the SSD should help this. I was also considering win 7 but am unsure if it will have all the drivers i need?
    So what's peoples opinions?
    Thanks!
    Variable Bitrate csfile's Avatar
    Feb 2009
    I've been happy with winxp - minimally slimmed down, using minlogon, ewf, and horm
    Oct 2006
    i have heard of minlogon what is ewf and horm
    Maximum Bitrate Crinos's Avatar
    Mar 2009
    Kristiansand, Norway
    Win2k is better than xp in boot times.
    Win2k is 32 bit
    Windows 7 can be 64 bit...
    Oct 2006
    64bit would be faster boot?
    Nov 2006
    Rubidoux, CA
    no, not necessarily, there's also little reason for a 64-bit os in a carpc. not going to use that much ram, and there are no 64-bit apps for it. All it does is complicate driver compatibility.
    2000 Ford Expedition Eddie Bauer - Bi-Fuel Gasoline/CNG
    Intel D945GCLF2 w/512MB RAM, CL Audigy w/KxProject, M2-ATX, Lilliput EBY701
    Nov 2006
    Rubidoux, CA
    I would second the recomendation for a stripped down winxp. Best boot times possible if you go with the EWF/HORM route (basically, as long as it takes to read your amount of RAM from the harddrive and reset driver states, and you're up). Also, guaranteed same state every time... much more 'appliance' like.
    Oct 2006
    sound like ill be going for stripped xp then, would you recommend nlite?
    i figure that the ssd will allow me to get fast times, especially from hibernate. Is it the power settings in windows i need to change so that when the opus 90W powers down it hibernates insted of shutting down fully? thanks!
    Mar 2009
    Quote Originally Posted by CraziFuzzy View Post
    I beg the differ.
    Boot times are better on 64bit system. (Atleast on my Quad Core 2.67Ghz)
    I have not written down the exact numbers, but tested it on the beta of win7
    Linux wise... I have not tested it yet... Perhaps Kev can answer this better?
    There's perhaps, no frontend system that is 64bit... yet... but there will be soon.. My own will be 64-bit only.
    Elsewhere
    Quote Originally Posted by drummerian View Post
    nLite is not a stripped-out version of XP. IT is a tool to create an XP install CD that is customized for your needs.
    And unless you know what you're doing, I would start with a plain installation of XP first, and start removing things as you go. Once you get it stripped down to the way you want it, then use nLite to create an install disc.
    Correct. There is a setting for what you want the computer to do when you press the power button.
    Make certain your video drivers are properly installed first. For whatever reason, Windoze doesn't allow you to enable hibernation if the proper video drivers aren't installed.
    How about the Wiki?
  1. what os best for Dell GX150 carpc
    By adamopel in forum Operating System Optimization
    Last Post: 02-26-2008, 05:11 PM
  2. Review: Windows Vista as an OS choice?
    By Splash-X in forum Software & Software Development
    Last Post: 05-24-2006, 12:58 PM
  3. USB Thumbstick Embedded OS?
    By hydraulix in forum General Hardware Discussion
    Last Post: 11-03-2004, 09:45 PM
  4. The Os and The Car
    By SjLucky in forum Software & Software Development
    Last Post: 06-24-2004, 03:09 PM
  5. A few observations in OS and why I'm now using Windows 2003...
    By Mastiff in forum Software & Software Development
    Last Post: 01-21-2004, 10:11 AM
