Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Tiny7 - Hybrid Sleep not available
    Jan 2008
    Unhappy Tiny7 - Hybrid Sleep not available
    As per title, I can't seem to get the hybrid sleep option to appear in my build. VIA MII-12000, Tiny7 rev 1.
    "powercfg - a" shows S1, S3, and Hibernate are available, however hybrid sleep is not. No reason is given, it's just listed under modes that are not supported
    Sleep and Hibernate both work fine.
    Anyone have any thoughts as to why this option is not available, or how I might enable it? Anyone have hybrid sleep working on an MII-12000? Tiny7 rev 1?
    Frustrating!
    --Nick
    Perth, Australia
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Power Options->Change Plan Settings->change advanced power settings->Sleep->Allow Hybrid Sleep
    If its not there...are hibernate and sleep both there? Are they both enabled?
    Jan 2008
    Appreciate the reply unfortuately Hibernate and Sleep are in that "advanced power settings" menu (enabled & working), but Hybrid Sleep is not. I assume because the OS thinks it is not available going by the "powercfg -a" results
    I would have thought Hibernate and Sleep were the only prerequisites for Hybrid Sleep...?
    Elsewhere
    Probably because that's one feature that was stripped out of that Tiny Win7 variant.
    This is another example of why I recommend AGAINST using the stripped-out Windows variants that someone else creates.
    Unless the creator of that variant details every file, service, component and feature that is removed or disabled, you have no clue as to what Windows functionality works and what doesn't.
    If you want a lightweight Windows, you really should install a full version and strip it out yourself, either manually or with a tool like nLite/vLite.
    How about the Wiki?
    Low Bitrate eigenVector's Avatar
    Apr 2009
    I agree with DarquePervert on this one. Install a full version and strip it out yourself.
    As far as hybrid sleep goes, I'm using a variant using both sleep and hibernation. I've configure my computer to sleep on power off, so that when I make short stops at gas stations and for coffee it'll wake back up quickly. But I also have it configured to auto-hibernate after sleeping for > 30 minutes (It semi wakes itself back up to hibernate.) Since I'm using an SSD, this prevents the forced memory disk write except for when I'm out of the car for longer than 30 minutes, when I'm likely going to be out for a while.
    Hybrid sleep works well if you're worried about either sleep not working, or if you expect your power supply to pull the plug at any time. My Opus PSU automatically kills power when my battery level drops too low, but this doesn't occur within my 30 minute window.
    Jan 2008
    Yeah I supposed there's a good chance that something needed has been stripped out like you say. I'll give it a go with the full version and see if it works. Thanks for the replies guys.
    Quote Originally Posted by eigenVector View Post
    Now that's interesting. I haven't come across this sort of thing before... is this a built-in feature/option? This is what I wanted from Hybrid Sleep, and my only real reason for migrating to Win7.
    --Nick
    Apr 2009
    Quote Originally Posted by incognico View Post
    Yea, it's built in for win7 (probably works for vista and maybe earlier, dunno).
    I think this is the right options I have set:
    In advanced power options
    - Disable hybrid sleep
    - Under Power buttons and lid options
    ---- Power button action set to Sleep. (or whatever action your computer takes when you cut the car off)
    - Under sleep options set to never sleep
    - Under hibernate options set to hibernate after 30 minutes (or whatever time interval you want it to hibernate in)
    I can send some screenshots from my install later this evening
    Keep in mind the hibernate interval will still attempt to hibernate your computer while your car is on, if it hasn't received any user input after the length specified. I'd set it to a long enough duration that you know your cars battery can easily handle. My car can easily do an hour in sleep mode (haven't tried anything longer than that.) but 30 minutes seems to work well enough for me.
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    looooool
    This is not what hibryd sleep do. When you set hibernate after 30min then if you not move mouse 30min pc will go to hibernate. So if you drive 30min without pressing anything on touchscreen it will automatic go to hibernate...
    Apr 2009
    Quote Originally Posted by _Dejan_ View Post
    looooool
    Yes Dejan, I have explained this in my post above as well. I hardly ever leave my computer screen un-touched within 30 minutes, which is why I choose the 30 minute interval. But I could have easily chosen the 1 hour interval.
    But what this approach does benefit from is allowing the user to quickly sleep the computer without having to write memory to the hibernate file every time while still allowing the computer to enter hibernation mode when I leave the car for longer than 30 minutes. The hybrid sleep ALWAYS writes to your hibernate file, even if you're just leaving it off for a few minutes, which isn't very valuable for my setup and usage.
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    But what this approach does benefit from is allowing the user to quickly sleep the computer without having to write memory to the hibernate file every time while still allowing the computer to enter hibernation mode when I leave the car for longer than 30 minutes. The hybrid sleep ALWAYS rights to your hibernate file, even if you're just leaving it off for a few minutes, which isn't very valuable for my setup and usage.
    Yes this is true and for a lot of users is this good solution BUT you can easy lose your data. Why?
    Example:
    You put your PC in sleep and you have setup your PCU that cut off power if voltage go bellow 11.5V. When you are turn it off you have 11.6V and after 10min fall under 11.5V and PSU cut off power. When you came back windows start normaly booting but cuting off power can defect some files and make error on booting or something else...
    With hibryd sleep this can't be happened... I hope that you understand what I would like to tell... But your solution is good for someone which motherboard do not support hibryd sleep or someone who don't want use it...
  1. Hybrid sleep
    By tripzero in forum LinuxICE
    Last Post: 10-16-2009, 01:47 PM
  2. Invoke full sleep with Apple TV
    By narkotic in forum General Hardware Discussion
    Last Post: 08-24-2009, 02:22 PM
  3. AMD Phenom 9850BE based CarPC
    By eigenVector in forum Newbie
    Last Post: 05-15-2009, 10:15 AM
  4. Proper Hibernation setup, NOT Sleep for fast powerups...
    By WuNgUn in forum Operating System Optimization
    Last Post: 02-24-2008, 06:26 PM
  5. Sleep &*Wake up control
    By Jirka Jirout in forum MacCar
    Last Post: 03-13-2007, 12:32 PM
