not for me... do you know of a different way to enable it?
It's in the Advanced Power Options control panel
EWF, HORM, MinLogon on XP.
Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
Win Embedded Std 2011 RC
OCZ Vertex Turbo 30GB SSD
Lilliput 629 Transflective, WRX Screen Mount
BlueSoleil BT, i-Blue GM-2 GPS, DirectedHD Radio, Andrea Mic
VoomPC 2
'93 Toyota Celica - First Car PC install
Current System Specs:
ZOTAC GF8200-C-E AM2+ GF8200
AMD Athlon 64 X2 3800+
1 GB DDR2 667
LITE-ON DL-8ATS Slot-Load
750 GB Seagate SATA HDD
250W PSU
19" Hyundai Monitor
you'll need a properly installed graphic driver before you can enable hybrid sleep.
Also you should enable S3 sleep in your bios setting as well.
Control Panel Items\Power Options\Edit Plan Settings\Change advance power system\Sleep\Enable Hybrid Sleep
Ah that was it! I had to enable S3 in the bios. I was just looking at those settings earlier today wondering what they were too. Thanks. Now how do I know when it goes into hibernation?
Before in sleep mode it would keep the cpu fan running so i figured i could tell when it went to hibernate because the cpu fan would stop, but now the cpu fan stops for both.
1 GB DDR2 667
250W PSU
19" Hyundai Monitor
in s3 almost everything stops except for ram voltage, which u can't tell.
to test, you wake the computer up with power normally, and it should wake up instantly, thats s3 wake up.
To test hibernation, put the computer back to sleep, pull out the AC power, and plug it back in after. Now turn on your computer, it should have the usual hibernation startup, if everything is setup correctly.
enjoy the greatest thing that happen to carpc!
yup it worked. thanks!
1 GB DDR2 667
250W PSU
19" Hyundai Monitor
Np, don't forget to get a psu that has sleep flexibility when you put it in the car.
I have no idea what that means. is that the soft off/hard off thing? if so, i do believe the m2-atx has that. which is what I have
1 GB DDR2 667
250W PSU
19" Hyundai Monitor
yeah the m2 has selectable jumpers to select how long before hard shutdown (5V shutdown). However it has a max limit of a few hours, which seems like what you want, some people like myself who wants more than a few hours would not want this psu.
Worklogs: 08 Sequoia Platinum Carputer (In Progress!)
Skin: MetroSex on the Beach preview
07 Infiniti Fx35 (done!) & 06 Infiniti M35 (gone...)
