Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: Windows 8 team focused on instant-on
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    Just heard about this. Looks interesting, hopefully it can be done.
    Microsoft's key area of focus appears to be performance and instant-on systems. "Windows 8 PC's turn on fast, nearly instantly in some cases, and are ready to work without any long or unexpected delays. When customers want to check e-mail, sports scores, or play media they love to reach for their PCs because they can get to what they want quickly."
    In what appears to be suggestions to OEMs, Microsoft details Windows 8 investments under consideration. Focusing on POST performance, S3 resume performance and general performance optimizations for each of the Off states are the key areas of improvement that Microsoft is aiming for with Windows 8 and Windows 8 enabled PCs.
    (source)
    That's the great thing about the iPad and smart phones. No resume from hibernation problems, actually that's their default and expected mode of operation. PCs should be like that, even if you need to fit a small battery to make it work safely, ALWAYS.
    Jan 2008
    while it is good to hear, if microsofts past is any indication of their future, i think i will wait until the whole instant-on feature is safely(and more stablely) implemented in windows 9...
    licensed to kill - FKA kev000
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    Quote Originally Posted by soundman98 View Post
    it'll be in windows 9 along with WINFS and all the other promised features that have disappeared from past OSs.
    That said, they did deliver all the feature they promised for window7 which was: "Windows7: better than vista".
    Note also that your phone rarely ever shuts down. It usually just turns off the screen and forces the cpu into lower profiles to save power. On ARM, the cpu will scale down to 0MHz when not used in this profile. This is usually different than suspend because you can still download stuff and receive calls in this state
    In a car, you could get away with doing this *if* your PC was power efficient enough not to drain your main battery. However, batteries do go dead, so starting up instantly in a cold boot type scenario would be essential.
    At any rate, my PC already does this: I turn off the monitor and it's "off" and I turn on the monitor and it's "on". This happens almost instantly.
    Former author of LinuxICE, nghost, nobdy.
    Current author of Automotive Message Broker (AMB).
    Works on Tizen IVI. Does not represent anyone or anything but himself.
    Dec 2007
    Danville, CA
    Quote Originally Posted by tripzero View Post
    Mine too, except I don't do anything other then press a button to start the car. However, my win7 hybrid sleep set up has its limits, it won't allow to be in that state forever - it will drain the battery. However, it works over one night, so that's good enough for now. Just not all drivers/MB work with that reliably, luckily mine does.
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    I wonder if this would require some kind of collaboration with hardware manufacturers, or whether this can be a purely software thing?
    I dont really mind boot times to be honest, since I just use standby on my laptop. But for the carpc this would be great.
    FLAC SFiorito's Avatar
    May 2004
    Hybrid sleep shouldn't be draining your battery when you leave it longer than over night. If you set your PSU to kill power after a certain amount of time (e.g. 30-60 mins) then you don't have to worry. Any time beyond that it will simply resume from hibernation, otherwise it resume from sleep.
    Quote Originally Posted by RipplingHurst View Post
    EWF, HORM, MinLogon on XP.
    Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
    Win Embedded Std 2011 RC
    OCZ Vertex Turbo 30GB SSD
    Lilliput 629 Transflective, WRX Screen Mount
    BlueSoleil BT, i-Blue GM-2 GPS, DirectedHD Radio, Andrea Mic
    VoomPC 2
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    I would settle for just an instant-boot bios in any small form factor. Seems like laptops only for now.
    Who knows how long it will be before win8 compliant hardware would make it into the embedded devices scene.
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    One of the things we hope to show at AFKFest in the connected car demo is many of the cool things that you can do when the car is off. Things that aren't currently possible when the PC is off due to being suspended/hibernated.
    Quote Originally Posted by justchat_1 View Post
    Buy a Clarion Mind and rip out the atom board. IIRC it's got the instant-on bios built in.
    Dec 2007
    Danville, CA
    Quote Originally Posted by SFiorito View Post
    I can't do that with my DSATX though, I have to trust their voltage monitoring system. When I turn off IGN, it stays on for 3 min, then Windows goes to hybrid sleep. When DATX detects voltage to be below 11.5v it then cuts 5v power to the RAM memory windows requires for hybrid sleep.
    And the problem is, I still use an old ATX psu (400W, with a 20A rail) that when I connect it to the car (rarely nowadays, but it's nice to be able to do it) only delivers 11.9v tops, 11.6 under load or less (disk defrag, media database updating, etc.). That forces the DSATX to send a shutdown signal.
    That is what I mean when I said the hybrid sleep is killing my battery, actually is the fact that I can't set a time for the DASTX to cut it off, not a high enough voltage to keep my battery healthy. So on the weekends I power the computer off manually - no hybrid sleep until Monday.
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    But again...those are low powered devices...not powerless devices...they still consume far more power then a typical car's electronics in standby (even though they consume quite a bit less then even a ulv pc).
  1. Windows 7 installation and lilliput 7" display
    By URAN in forum Software & Software Development
    Last Post: 10-03-2009, 01:37 AM
  2. New Frontend for Windows and Linux
    By gbr in forum Other Cool Front Ends
    Last Post: 01-21-2009, 09:55 PM
  3. Installing Windows 2000 Pro on a 1GB Microdrive
    By JeremyM in forum WinNT Based
    Last Post: 05-07-2005, 10:56 PM
  4. Windows Freeze When Crank, Crank again windows unfreeze
    By antimatter in forum Power Supplies
    Last Post: 07-27-2004, 01:40 AM
  5. Windows ME and MediaCar
    By dug1967 in forum MediaCar
    Last Post: 04-15-2004, 02:30 PM
