Results 1 to 2 of 2
Thread: Hibernates but nothing running??
    Aug 2010
    Hey guys, a bit weird this. I have a fairly new Via EPIA cn13000 mainboard with 1 gig of 533MHz DDR2 ram and am running XP with SP3 installed. The system works as expected and I have the double throw switch for permanent or ignition on etc. I am using the M2 ATX HV power supply
    My problem comes when XP hibernates. It goes down fine after the alloted time. If I then restart the car, the BIOS loads and then I get the resuming windows message as expected but once the desktop loads, there is nothign else running, ie all other programs have been shutdown. As first I thought this was my custom software but in debug mode, it registers the hibernation suspend mode and thats it. Its almost like XP is actually restarting from cold, even though it says its resuming from hibernation. I tried with other programs such as media player and even just explorer windows but they all just close down or are not running.
    Has anyone else experienced similar symptoms or can you point me in the right direction of where to start looking for a fix as I am totally stumped after a week of looking...
    I googled this problem but got no specific hits, just problems with USB devices after resume..? Anyone out there able to help? Thanks
    Aug 2010
    Fixed this problem if anyone else has the same setup as me as it was very odd.
    I found that if with the vehicle ignition on and engine running I toggled my 3 way switch to off (i set up the standard perm on, ign on or off 3 way switch to feed my power supply IGN wire), then m2 ATX would correctly after 30 seconds or so send the signal to the PC which would hibernate correctly. If however I left the toggle switch in "ignition" mode and just shut off the ignition at the key (stopped engine), the ATX power supply would just cut the power to the PC and it would be instant off (no shut down or hibernate) as if I had pulled the power lead out of the back of my home PC.
    I had not realised this was happening because a) the screen would go off and b) when i restarted, I was getting the windows resume message making me assume the system had actually hibernated. So the problem was that it seemed to be resuming but no programs were running.
    It appear that the problem was that I naively had the 12V power (continuous) to M2 ATX supplied from my secondary leisure battery but was using the 12V ignition supply from main battery with common earth of car body and this disparity in power sources was causing the issue ( i think).
    To fix it, I just used the 12v ignition supply to switch a relay in the end and sorted it that way.. I think the PC was showing as resuming even though it had been just powered off was because the hiberfile remained on the system (might be wrong though)..
    for info, my install is in a VW T5 van so I have a secondary battery fitted to power the auxiliary stuff and had wanted the car pc to be run off that so that in the event of a ATX power supply problem / PC locking up on hibernate, it would not drain down my main cranking battery..
  1. Opus unable stay running unless car is also running
    By Mears in forum Power Supplies
    Last Post: 09-20-2009, 03:08 PM
  2. Replies: 3
    Last Post: 11-08-2008, 10:58 PM
  3. Replies: 4
    Last Post: 02-05-2008, 12:20 PM
  4. power problems while car is running..
    By TimW in forum General Hardware Discussion
    Last Post: 03-18-2006, 09:11 PM
  5. Replies: 23
    Last Post: 03-21-2005, 03:45 AM
