Results 1 to 4 of 4
Thread: Need help with grub bootloader
    Maximum Bitrate locs4dayz's Avatar
    Sep 2009
    Philadelphia, PA
    Question Need help with grub bootloader
    Can grub be used to boot anything other than a physical HDD or physical flash drive partition?How?
    I have tried everything I can find online, but nothing works. I know it can't boot iso's, but can it boot any other type of file from the physical HDD successfully???
    How do I boot a file or virtual hard disk image from grub? Really need an answer on this!
    Linux(Learning the curve...Like when driving!!!)
    Worklog!!!http://www.mp3car.com/vbulletin/fabr...l-worklog.html
    Jun 2009
    hey dude you should look at grub2. you can use the loopback module to boot a FS image (ext2 and 3 should work)
    Sep 2009
    Philadelphia, PA
    Hopefully someone will eventually post a solution to this problem(would like my main carpc features to be installed on the primary drive). In the mean time, I've got a 40Gig Maxtor HDD laying around that I am going to add to my system today to get he job done instead...
    Thanks in advance for any working solution though!!!
    UPDATE: The Maxtor is in...formating it now but I forgot to hook the antennae back up, so I gotta go back in one more time after its done...hopefully!!!
    Aug 2011
    Still confused as to what u are trying to boot up exactly...
    Grub2 will boot up pretty much all linux / bsd etc from an any / filesystem its supports i.e ext2/3 reiserfs / iso etc...
    Just need to pass the right info to the kernel its launchin where root is & kernel (options)
    Grub2 wont pretend to be a virtual dvd drive & fool what its launching,
    So i am gonna assume u tryin to update / reinstall windows, which u really want to be lookin @ grub4dos.
    Or better if your bios supports booting from usb, its a much better solution.
    But anyway more info on what u are trying todo will make it easier to help
  1. How to add Recovery options to Win 7 bootloader!!!!!!
    By locs4dayz in forum Operating System Optimization
    Last Post: 12-01-2010, 05:52 PM
  2. Trying to boot vhd's from grub! Almost there!!!!
    Last Post: 11-30-2010, 04:30 AM
  3. Need help booting iso from grub!!!
    Last Post: 11-29-2010, 03:10 PM
  4. TomTom BootLoader V.2.0
    By DaveDevil in forum Software & Software Development
    Last Post: 01-03-2009, 07:58 PM
  5. Select OS in grub whiout keyboard
    By stoker in forum Linux
    Last Post: 04-11-2007, 11:52 AM
