Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Hybrid-sleep, Win7 trying to solve a strange problem.
  1. #11
    FLAC Mickz's Avatar
    Sep 2009
    Australia
    Yes, already have a plan on dropping the single USB feed to the three front hubs. The thing to keep in mind is that when you reconnect the HUB there will be a sudden current draw from all devices on the USB line (caps charging) and once again dependent on hardware, and exactly what the PSU does with its +5 STB line in that situation will again be hardware dependent.
    I have that situation mostly covered, so when I get a chance I’m going to do some tests.
    Palm sized ainol MiniPC, 8" Transreflective PRO, Win10, Reverse camera, Dual 10HZ GPS RX's for Speed Display & Sat Nav, FM-DAB & Phone Modules, iDrive interface. T-Screen HVAC control, custom microcontrollers, microcode and FE.
  2. #12
    FLAC Mickz's Avatar
    Sep 2009
    Australia
    As I suspected, my +5v STB line drops the instant any USB device is unplugged. Either MB or PSU is seeing this. When I get a chance I’ll find out which.
  3. #13
    FLAC Mickz's Avatar
    Sep 2009
    Australia
    Found a way around the problem.
    My FE monitors the position of the Auto/Manual switch in the centre console. This is the switch going to the IGN input (On/Off line) of the M4-PSU.
    I had the FE set up so that if the IGN was fully on (ready to start the car or the car running) and the Auto/Man switch is depressed (turned off) then the FE will issue a shutdown cmd to the Car-PC. I have the M4 set for a 12 Seconds wait before signalling the PC motherboard – power on/off line.
    I have that delay to give the FE time to stop Camera recordings, close the camera apps, stop the radio app and com-port if it’s open (that stops the PC going into sleep and sometimes in hibernate correctly) and all in a timely manner.
    Anyway, I changed the code to Hibernate the PC instead of shutdown (I have a sub menu item button for shutdown anyway).
    Now I can control when I don’t want the PC to go into “automatic” Sleep state (IGN turned off normally).
    I just depress the Auto/Man button, wait a second until the FE announces it's going to hibernate and then turn the car off. Works perfectly. Solves long sleep/power usage times when I don't need them.
    Here’s another brilliant feature (not) of the M4. If the PC is in sleep (or hibernate with +5v STB), any slight pulse on the IGN line (On/Off line to the M4) will instantly drop +5v standby on my unit, no matter how long you have the M4 set to NOT respond to the IGN line.
    EDIT: Which takes me back to the original problem I had with sleep and the M4 a year or more ago, that’s when I posted that Cap and Diode mod for the M4 IGN line to stop it randomly causing resume from sleep to fail if the car was cranked.
  4. #14
    Low Bitrate Zephrant's Avatar
    Sep 2010
    What do you have your dip switches set to on the M4?
    Do you have part numbers of the filter caps you put on it? My car radio is almost unusable when the PC is in the car, so I've got to start filtering as well.
  5. #15
    FLAC Mickz's Avatar
    Sep 2009
    Australia
    I’m using Mode 1.
    Hard Off timer is set to 7 hours.
    Power off timer is now 5 seconds.
    Emergency off is 60 seconds.
    Windows setting for “what does the PC (hardware) button do” is set to “nothing” with this new mod.
    I now have the system set up to:
    Auto Shutdown if the Auto/Man switch is turned off while the vehicle IGN SW is in Full ON.
    Auto Hibernate if the Auto/Man button is turned off while the vehicle IGN SW is in ACC.
    Auto Sleep if the vehicle IGN SW is simply turned off.
    BTW – A small device (almost no current draw) can be unplugged and 5v STBY stays. A HUB with a few devices that is unplugged will drop +5v STBY.
    I’ll have to find the post I did on the forum in the M4 section for the mods and give you the link, the RF feed-through caps are getting costly and the M4-PCB has to be placed into an aluminium or copper case made from single or double side PCB cut and soldered together.
  6. #16
    Variable Bitrate eugenweij's Avatar
    Aug 2010
    Rozenburg, Netherlands
    Quote Originally Posted by kegobeer View Post
    There are quite a few people that have issues when resuming from hybrid sleep when power has been disconnected. Some people see wait times of over 5 minutes when a normal hibernation resume takes seconds. I never use hybrid sleep for that very reason. My E350M1 resumes from hibernation in about 5 seconds (4GB RAM, hibernation file set at 100%, SSD, Windows 7 Ultimate x86, CF as my front-end, with GPS and OBD-II on a RAM tough hub), which is plenty quick. My previous board, a D510MO, took a bit longer to resume, but I didn't mind the wait because it was rock solid and didn't have any problems.
    My personal opinion is that some motherboards don't handle hybrid sleep very well after a power loss.
    I know its a year later but I would like to know how you setup your system to boot from hibernate this fast , I have the same board and a silicon power T10 SSd 4gb ram and all usb connected through a powered usb hub.
    It takes me 40 seconds to boot from hibernate
    View my worklog here
  1. Replies: 10
    Last Post: 09-05-2011, 06:26 PM
  2. Win 7 Hybrid Sleep and the 5 volt rail
    By TheJack in forum General Hardware Discussion
    Last Post: 08-28-2010, 02:09 AM
  3. Hybrid Sleep for XP?
    By HiJackZX1 in forum Software & Software Development
    Last Post: 03-02-2010, 01:43 AM
  4. Tiny7 - Hybrid Sleep not available
    By incognico in forum Operating System Optimization
    Last Post: 10-23-2009, 11:14 PM
  5. Hybrid sleep
    By tripzero in forum LinuxICE
    Last Post: 10-16-2009, 01:47 PM
