Results 1 to 5 of 5
Thread: Windows xp hibernation issue
    Variable Bitrate rizaydog's Avatar
    Nov 2007
    North Central PA
    I decided to upgrade my old laptop hard drive to a larger SSD drive. After installing a fresh copy of xp, I installed all of the software I had on my other hard drive. Roadrunner, Iguidance, winamp, windows media player classic ect... In the control panel, I change the power option to hibernate just like I had done before. Now when I shut my car off, I get the screen that says hibernating. After about 30 seconds, the pc hibernates but then reboots. It stays on for a minute and hibernates again. This cycle continues. The only way I can stop it is to quickly change the hibernation back to power off.
    Any idea what could be the cause/solution?
    I told my psychiatrist that everyone hates me. He said I was being ridiculous - everyone hasn't met me yet .
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    In your bios is it set to power on after power failure or return to previous state after power failure. Just a thought SNO
    Nov 2007
    North Central PA
    I did check that. It's set to stay off.
    I have sp3 on this. I can't remember if I had that before. Maybe I'll try to remove it and see what happens.
    Elsewhere
    I'm betting a USB device is waking the PC.
    Check the power settings for USB controllers and/or devices to make sure the PC won't wake up when receiving a signal from a USB device.
    Also, go through he power settings in Control Panel to see if it is set to allow USB devices to wake the computer from sleep/hibernate.
    How about the Wiki?
    Variable Bitrate chris350's Avatar
    Aug 2007
    Queens, NYC
    +1 ^^^ check the USB devices
    CarPc
    Project "Driver"
    Planning [99.9%]
    Parts Collected [98.5%]
    Installation & Fabrication [98%]
    Total Completion Level [96.9 %]
    http://www.mp3car.com/vbulletin/work...ct-driver.html
  1. Hibernation issue
    By koll48 in forum General Hardware Discussion
    Last Post: 10-19-2009, 03:29 PM
  2. windows XP shutdown/hibernation issue?
    By wishbone in forum WinNT Based
    Last Post: 11-14-2007, 08:29 PM
  3. CF & Hibernation Issue
    By mmk999 in forum CF Bug Reports
    Last Post: 04-27-2006, 01:16 PM
  4. I'm having a hibernation issue
    By n8scstm in forum Road Runner
    Last Post: 03-28-2006, 02:23 PM
  5. Replies: 4
    Last Post: 10-10-2005, 01:56 PM
