Results 1 to 9 of 9
Thread: Extend WinXP security updates!
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    I have found a little reg hack to get security updates for XP, Support ended this April for XP but with this reg hack you can get security updates for XP. It tricks XP into thinking it's the embedded pos 2009 version which has support till April 2019. Save in notepad as a txt file and then rename the extension to .reg run it and get your security updates.
    [HKEY_LOCAL_MACHINE\SYSTEM\WPA\PosReady]
    "Installed"=dword:00000001
    Hope this helps SNO
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    That's pretty cool!
    Sent from my iPhone using Tapatalk
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Sticking it in notepad as it is above didn't work.
    So I exported a similar key, edited it and then re-imported.
    Just wonder if it has any side effects. hmmmm?
    FLAC mauri's Avatar
    Jan 2004
    Try this.
    Attached Files Attached Files
    Nov 2009
    Keswick,On Canada
    I just add a new key and then edited the the dword. works like a charm tried before and no updates found after reg edit found 4 updates 2 related to pos but 2 more related to .net. Works on all my XP boxes. SNO
    Nov 2009
    Keswick,On Canada
    Love this hack 6 new updates today, even 1 for ie8 SNO
    May 2012
    Grandville, MI
    Hmm I tried it on a vmware image I had and it didn't work...
    Will have to try it again soon.
    Rodney
  1. Best way to extend the USB and VGA on Lilliput
    By brianteel in forum LCD/Display
    Last Post: 12-13-2009, 06:48 AM
  2. Trying to extend a usb cable
    By migitcheetah in forum General Hardware Discussion
    Last Post: 10-23-2009, 06:00 PM
  3. Replies: 3
    Last Post: 02-10-2007, 02:20 AM
  4. extend GPS antenna??
    By ramy_zohair in forum GPS
    Last Post: 09-30-2005, 05:26 PM
  5. extend a PCI slot?
    By schrodos in forum General Hardware Discussion
    Last Post: 07-25-2002, 05:36 PM
