Cool ... can post your nLite config when you're done?
well, spend quite a while last night getting a functional nLited windows to work. I still have yet to try the latest build but here is what I was having trouble with (you might benefit from this)
on build 7 of my nlite it seemed like everything was going to work... My OEM GPS which is attached to an internal, com2 of my via MII10000 board was having an IRQ conflict after a fresh install. This was because I hadn't yet installed the via (4 in 1 drivers) which includes a set of instructions of IRQ's for the com ports among other important PCI data to the OS.
Upon running the 4 in 1 setup, it was crashing.... Why was it crashing ?? because aparently the extractor utility is a 16 bit application !!!! WHAT THE CRAP !!!! who uses 16 bit aps nowa days ???
On to build 8, setup utility doesnt crash, extracts the data but doesn't run... WHY ?? because with nLite 1.9.77 you also need to apply the 16 bit "patch just undernieth 16 bit aps"
On to Build 9... I'll update you all to let you know if I've succedded.
Progress [I will seriously never be done!]
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
1GB Extreme III CF card
Carnetix 1260 startup/ DC-DC regulator
Software: Still, re-Writing my existing front end in .Net
BTW I believe 4in1 Setup.exe is just selfextracting archive which can be unpacked using Winzip on your desktop machine. Then you could possibly install unpacked drivers via their INF files rather then via setup engine. No need for 16 bit support then.
I think that there are ways to extract the .exe. When you do that, you should be able to load up the drivers from device manager. That's what people were froced to do when VIA introduced a bug into their exe file![]()
once you unpack the files the setup is still 16 bit, i tried that in hopes it would work with my laptop and burned the extracted files to a cd.. still no luck..
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
with page file disabled on a completely fresh install I'm getting about 360MB (this is without moving ANYTHING, so you can definatly get this down to 250 with a little effort)
Code:[Main] Env = 0.99.7 beta.1.1.4322.2032.Microsoft Windows NT 5.1.2600.0..en-US Target = Windows XP Professional SP2 - build 2180 [Pages] Integrate a Service Pack Remove Components Unattended Setup Options and Tweaks Create a Bootable ISO [Components] ;# Applications # Accessibility Options Briefcase Calculator Charmap ClipBook Viewer Games Internet Games NT Backup Pinball Screensavers Wordpad ;# Drivers # Battery Bluetooth Support Cameras and Camcorders Display Adapters Display Adapters (old) Ethernet (LAN) Firewire (1394) IBM Thinkpad InfraRed ISDN Modems MultiFunctional Multi-port serial adapters Portable Audio Printers Scanners SCSI/RAID Sound Controllers Toshiba DVD decoder card Windows Image Acquisition (WIA) Wireless Ethernet (WLAN) ;# Internet Utilities # Client for Netware Networks Communication tools FrontPage Extensions Internet Connection Wizard Internet Explorer Internet Information Services (IIS) MSN Explorer Netmeeting NetShell Cmd-Tool Network Monitor Driver and Tools NWLink IPX/SPX/NetBIOS Protocol Outlook Express Peer-to-Peer Synchronization Manager Vector Graphics Rendering (VML) Web Folders Windows Messenger ;# Multimedia # Images and Backgrounds Luna Theme Media Center MIDI audio support Mouse Cursors Movie Maker Music Samples Old CDPlayer and Sound Recorder Paint Tablet PC Windows Media Player Windows Media Player 6.4 Windows Sounds ;# Operating System Options # Desktop Cleanup Wizard Disk Cleanup DR Watson File and Settings Wizard Help Manual Install and Upgrade Printer Support Search Assistant Security Center Shell Media Handler Tour Web View ;# Services # Alerter Application Layer Gateway Autoupdate CTF Loader Distributed Link Tracking Client Distributed Transaction Coordinator (DTC) DNS Client Error Reporting Fax Services Imapi Indexing Service IPSEC Policy Agent Messenger Network DDE QoS RSVP Quality of Service (Qos) Remote Registry Removable Storage Secondary Logon Service Advertising Protocol SNMP TCP/IP NetBIOS Helper Telnet Server Terminal Services Uninterruptible Power Supply Universal Plug and Play Volume Shadow Copy WebClient Windows Firewall/Internet Connection Sharing (ICS) Windows Time ;# Language Support # Arabic Baltic Central Europe Chinese Simplified Chinese Traditional Cyrillic Georgian Greek Hebrew Indian Japanese Korean Thai Turkish Vietnamese Multilanguage Support (LANG dir) Service Pack Messages Input Method Editor ;# Directories # DOCS SUPPORT VALUEADD [KeepFiles] [RemoveFiles] [Options] ;# Desktop,Taskbar & Startmenu # ;# Experimental # ;# Explorer # ;# Security & Privacy # ;# Speed # ;# Visual Effects # ProfilesDir = "%SystemDrive%\Documents and Settings" ;#ISO maker# isovol = WInLITE isoatt = -allow-multidot -relaxed-filenames -allow-leading-dots -N -l -d -D -joliet-long -duplicates-once -no-emul-boot -b boot.bin -hide boot.bin -hide boot.catalog
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
