Results 11 to 20 of 29
Thread: Partitions: Good or Bad?
  1. #11
    Variable Bitrate roadhog's Avatar
    Jul 2005
    Hampshire UK
    I have a 250gb drive split into 3 partitions.
    OS and programs - I figured this will change quite often and I was right. @ 25gb it defrags a lot quicker than the whole disk.
    Data - Well media to be more precise. This rarely changes, just new files added occasionally.
    Backups - Not mission critical, just a Ghost of the O/S and various device drivers and program archives. If I need to re-install anything I can do it from here.
    The main reason I did it like this was to avoid defragging the whole drive too often.
  2. #12
    Variable Bitrate Pokey's Avatar
    Tampa, Florida
    I agree with most users.... two partitions are good. One for the OS (programs & Windows) and one for the Data files (movies and music)..
    I have 3 partitions... on the third partition i keep a backup of each partition. (1 and 2 seperate)...of course this requires a large HD, but now adays a 300G goes for less than $100..
    Dual Lilliput's 70NP/C/T
    Syntax SV266AD KT266A
    AMD Athlon XP 2000
    Viking 256MB DDR
    D-Link Wireless 802.11B
    Seagate 120GB
    OrbitMicro 250W DC/DC converter
    SII Wireless Audio Link
    Digimoto OBD-II
    Earthmate GPS
    BU-303 USB GPS
    D-Link Bluetooth
  3. #13
    Banned RPM_VR4's Avatar
    Nov 2004
    L.A.
    Partitioning just limits your contiguous free space for no reason if you ask me. If you install into a new directory, you really don't need to reformat when reinstalling the OS.
    Besides, prices are 30 cents per GB on E-Bay right now. Use the entire old drive for the OS and buy a new huge drive for your media. Why not just have multiple HDDs (and network drives)? At home I have 3 computers (HTPC, Bedroom PC, Office PC) that share: a drive for DVD-Rips, a drive for TV-Recordings, a drive for current/recent Azureous Downloads, a drive for Emulator/Video-Games, a drive for Music/Music-Videos/Discographies, a drive for applications and ISOs, and 3 drives for the OS's. 1.5TB in all.
  4. #14
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by roadhog
    seems we have a similar opinion here road hog, here's me quoting my post in the previously mentioned thread.
    Quote Originally Posted by Enforcer
    I partition my drive in 3.
    1 OS
    2. DATA
    3. Backup image (ie Ghost the base OS and one with all apps installed + Drivers)
    3 is fat32 so I can ghost back the system should it get corrupted or just need cleaning out. the other two are NTFS.
    However then new system wen it goes in will have two drives.
    one for OS and one for data.
    BTW it is recommended that the swap file be placed on a seperate disk to the system disk if more than one disk is installed. ALthough as the second disk will hold all the MP3's and DIVX's it might not be a goos idea, will have to look into that.
  5. #15
    Jul 2005
    Hampshire UK
    Ahem. Well as much as it may look like a blatent steal it wasn't, honest! Great minds think alike, or fools seldom differ...
  6. #16
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Partitions are good, you don't NEED them, but they only help not hinder. . .
  7. #17
    Nov 2004
    L.A.
    How do you figure?
    1) How do they help? The only use is if you like to re-format all the time. This is no longer necessary in todays PC world. You can do just as clean an install by renaming some directories before booting from CD.
    2) They totally hinder. If you make your boot partition too small it might fill up due to crappy programs that will only work off the boot-drive (large "common files" and such). If you make it to big then you have less room on your "media" partition for if your collection grows.
    I don't see any reason to run multiple partitions. In fact, if you have more than one extra HDD in your PC, I recommend running both secondary drives as a single striped partition (the only drawback is that if either of your drives total crash, all the data is gone... but a total HDD failure is very rare in my experience).
  8. #18
    Jul 2005
    Motorcity
    Blog Entries
    1
    Well partitions are basically the same as having multiple drives (much like you do) If you crash a partition the other one is usually recoverable. Its basically a cheap way to have multiple disks. If one partition is infected with a virus, the others are safe. Like I said they are not necessary but as a linux/unix user I know how to use them. If you don't know what your doing with partitioning I could see where you think they would be useless, but for the inclined they can be a VERY valuable tool. Partitons are what make the *nix O.S.'s so rock solid and stable. Different sections of the OS operating files are put on different partitions as to avoid conflict. It would be the same if windows used say a partition for all .DLL files, etc. Its the only file type the partition handles resulting in system stability. I could go on and on but for instance my Desktop has 3 - 80Gb harddrives and each harddrive has multiple partitions, and I would say my system is probably about 1000% more secure than yours. another example is when your dealing with high end applications, I use photoshop cs2 at work and I have setup a dedicated 3 gig "swap" partition that this app uses exclusively like RAM. Its called a scratch volume. It conserves system resources. Also windows "swaps" data into the pagefile.sys file on the C: drive which is a terriable design. Swap space is much more efficient when its on a seperate partition. These are the little things that make windows slow and buggy. If you still don't believe me think about this, the backbone of the internet are UNIX machines which, are multi partition, and can achieve uptime counted in YEARS. Anyway everyone is entilted to their opinion but ive ran systems both ways and partitions only help not hinder...
  9. #19
    Nov 2004
    L.A.
    For an OS that is designed to run off multiple partitions, they make sense. For a Windows home network on a router/firewall I still don't buy it. It is wise to keep the Windows swap-file on a separate drive (as I do). My main point is that with the price of HDDs these days, it is always better just to buy another drive rather than partitioning a single. How do you manage the partitions when you do start running out of space on one or the other?
  10. #20
    Low Bitrate grimor2000's Avatar
    Dec 2005
    Chicago-ish
    2-3 partions is just fine, one for OS/progs, one for media/file storage and if you want, one for back up.
    in a carPC enviroment, there are power and physical space concerns with adding a new hard drive. And I'm surprised that all the people here saying "what if you run out of space" have never used programs that allow you to resize your partitions on the fly (PQ Partition Magic anyone?) if you need more room on C but you have room on D, just slide the little bar over, wait a little while, and you have more room.
    Causa latet vis est notissima
    VIA SP13000
    1GB DDR400
    Slimline Slot-load DVD-RW
    60GB 2.5 Inch SATA 5400RPM
    Dual Active PCI riser
    PCI TV/FM card
    Logisys FP800
    Thermaltake VFD Media Lab
    M1-ATX
  1. Auto power off
    By accord in forum General Hardware Discussion
    Last Post: 08-15-2004, 08:08 AM
  2. Cell Booster / Amplifier
    By GruvThang in forum General Hardware Discussion
    Last Post: 07-28-2004, 07:35 AM
  3. Replies: 14
    Last Post: 07-05-2004, 12:43 AM
  4. Looks like a pretty good LCD monitor
    By Quattro in forum LCD/Display
    Last Post: 12-19-2003, 07:13 PM
  5. Are these a good LCD?
    By mainfraim in forum LCD/Display
    Last Post: 05-18-2002, 06:37 PM
