Results 1 to 10 of 14
Thread: onboard CF to ide->CF adapter.....won't boot anymore
    Mar 2004
    I have an old single board computer with an onboard CF slot. I had installed win98 on a CF card using the onboard slot, and discovered that the onboard CF was limiting the speed of the CF card
    So, I bought an ide->CF adapter. I know the adapter works fine, because I was able to boot off the CF like I had, and read the CF card from my camera using the adapter.
    When I plug the CF w/win98 on it into the adapter, I get an "invalid system disk" error when the computer tries to boot.
    I've already set up all the software on the win98 install, so I don't really want to go and reinstall win98 onto the CF card using the adapter. Is there a way to get it to work without reinstalling?
    edit: the actual error message is "DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER"
    Variable Bitrate roadhog's Avatar
    Jul 2005
    Hampshire UK
    Check in the BIOS which disk (CF adaptor) is set as the system disk, or bootable disk. Is the new cf slot is being assigned a different drive letter?
    Mar 2004
    Quote Originally Posted by roadhog
    Im not sure whether or not the CF card is being assigned a different drive letter.
    The only option that I can see being relevant is "Boot sequence." I've tried every option with that and get the same "invalid system disk" error when trying to boot
    edit2: I get the same error message if there is no disk inserted
    Newbie SlashEMc2k's Avatar
    Dec 2004
    UK
    check the boot up order and also make sure you haven`t got a floppy in the diskdrive.
    Maximum Bitrate LagunaICE's Avatar
    Mar 2005
    Czech republic
    BTW I wonder whether you had your CF card write protected.
    Mar 2004
    Quote Originally Posted by SlashEMc2k
    I've tried every possible boot up order, to no avail. There also isn't a floppy drive in the computer, so that's not it
    Quote Originally Posted by LagunaICE
    what exactly do you mean? To limit the write cycles, I just turned of the page file. I doubt the amount of write cycles will destroy the card any time soon, so I figured I'd see how long this one lasted and just buy another one when it dies
    Constant Bitrate faichiu's Avatar
    Make sure the bios see the CF card like a hard disk.
    98 Honda civic
    In-Dash LCD Monitor K-301
    cappuccino EZ3
    PIII-1.2GHZ
    256MB PC133
    40GB HD
    Holux GR 213 Sirf Star III GPS
    IguidanceV2
    CNX-P1900 power supply
    Sound Blaster Live USB
    Mar 2004
    Quote Originally Posted by faichiu
    There is an "IDE HDD auto detection" option on the BIOS, which reads out the same data for the CF card, whether it's using the adapter or onboard slot
    From that I'm assuming that it sees the CF as a hard drive
    Mar 2007
    IDE to Compact Flash
    IDE to Compact Flash :
    These units allow users to replace traditional hard drives with standard Compact Flash cards.
    There are some real nice bennefits to using compact flash in place of a regular hard drive.
    These include:
    - very low power consumption (less then 0.5W)
    - Fast startup, no spin up time, or USB bottleneck
    - high transfer rate
    - phisically very durable
    - compatibility with IDE drivers, nothing special needed
    - they are completely silent
    - The use commodity (cheap and plentiful) CF cards
    Feb 2008
    re:CF to IDE
    make sure your CF card work on the DMA mode , not PIO mode .
    IDE to CF Adapter,SATA to CF
    PCI Riser Card,IDE to SD/ZIF/SCSI/SlimCD-ROM
    making data communicate easy
    http://www.soarland.com/
  1. Replies: 10
    Last Post: 04-17-2006, 06:23 PM
  2. IDE to USB adapter & Hibernation problem
    By nkotch in forum General Hardware Discussion
    Last Post: 03-15-2006, 05:55 PM
  3. onboard CF slot reading slow (win98 + twinmos 140x card)
    By dyne in forum General Hardware Discussion
    Last Post: 03-04-2006, 11:19 PM
  4. IDE adapter and cable orientation
    By Musashi450 in forum Newbie
    Last Post: 01-04-2006, 06:43 PM
  5. boot from CF?
    By etrik in forum General Hardware Discussion
    Last Post: 02-09-2002, 02:08 PM
