Results 1 to 4 of 4
Thread: EPIA MII-12000, USB driver under svc pk 3?
    Constant Bitrate 01black_ac's Avatar
    Jul 2005
    NJ
    I'm testing my system with SVC PK 3 right now because it cuts the cold boot time by about 25 seconds versus SVC PK 4. However, I've got a problem installing drivers for the last USB controller onboard. I can't seem to find a driver which works. I've tried the ones from via's site, and also the ones from viaarena. Anyone have a solution for a working driver for the onboard USB controller under SVC PK 3?
    '01
    Hang on while I defragment my car...
    the Acura ITX project
    the Acura ITX skin for RoadRunner
    project progress: 99%
    Constant Bitrate m-ruiter's Avatar
    Jul 2005
    Kortenhoef
    Your doing this under ??:
    OS X , WinXP, Win2K, Linux or maybe you mean service pack 4 for OS/2 ?
    You'll at least have to give us some more information.
    Jul 2005
    NJ
    oops... yeah, win2k.
    '01
    _
    Mar 2004
    Little Elm, Texas
    this might or might not be the same, and yes, I know this is an old thread.
    I just recently reloaded windows on my carpc and ran into the same issue.
    I'm running XP SP2. When I tried to install the drivers from the CD, it told me I needed SP1 or newer...strange since I already have SP2.
    I couldn't get the USB port to work. This was preventing me from getting online as it was holding my USB WiFi dongle. So I had to install my wifi PCMCIA card in the PCMCIA slot on the board and get online there. Once online there I was able to auto update the driver and it worked. Every driver that I found and downloaded then transfered over to the CarPC didn't work. It only worked once I updated the drivers via windows.
    Jan Bennett
  1. VIA EPIA MII 12000 1.2Ghz Motherboard questions
    By arise360 in forum General Hardware Discussion
    Last Post: 12-30-2004, 02:38 PM
  2. anyway to avoid buying epia the mii 10000
    By jnusaira in forum General Hardware Discussion
    Last Post: 03-04-2004, 07:45 PM
  3. Replies: 6
    Last Post: 07-21-2003, 03:18 PM
  4. USB Sound Card with ASIO driver and volume control
    By tbdombrosky in forum General Hardware Discussion
    Last Post: 02-04-2003, 12:00 AM
  5. Via Epia Questions - need multiple serials, ps/2 ports, USB
    By nxt125 in forum General Hardware Discussion
    Last Post: 08-07-2002, 09:08 PM
