Results 1 to 6 of 6
Thread: hibernating in tinyxp
    Jan 2005
    i've installed a version of tinyxp
    my cold boot is like 30 secs, no less then my normal xp install
    i was wondering that maybe because of the low use of ram, hibernating would be faster.
    but how do i make tinyxp hibernate?
    Jan 2004
    NYC
    ok i did some searchin and found this, let me know if this works..
    I checked my desktop and was actually able to get to the hibernation/standby/power options on my laptop, with TinyXP. Just goto Start -> Run, and type
    C:\WINDOWS\system32\rundll32.exe C:\WINDOWS\system32\shell32.dll,Control_RunDLL powercfg.cpl,,
    TYPE ALL THAT IN THE RUN BOX AS ONE LINE
    then hit OK. Should bring up the window with the options.
    If you enable hibernation and it does NOT appear when you look at the shutdown list, try holding down shift. For me it only shows Standby, Shutdown, Restart, if i hold shift it replaces Standby with Hibernate.
    Jan 2004
    NYC
    rie, just update your video drivers and u should get the hibernation tab back
    Nov 2005
    Hold down shift at the Turn Off menu
    Elsewhere
    Quote Originally Posted by @rie
    Wrong. Hibernation writes the entire contents of RAM to a file, which means zeroes if there is nothing in a particular block of memory at the time you hibernate.
    How about the Wiki?
    Nov 2009
    Thunder Bay, Ontario, Canada
    i just ran camsngs command line and it worked perfect. The option for hibernation wasn't in control panel, power options. but after running that, it brought me into the same windows but the option was there!
    Even if I google it, the answer i find is usually from this board! thanks again mp3car community!
  1. PC 5740 HIBERNATING issues
    By MobiTekLink in forum Wireless Communications
    Last Post: 08-12-2006, 05:54 AM
  2. TinyXP rev02 cinergy 600 dont work
    By leckan in forum WinNT Based
    Last Post: 03-22-2006, 09:53 AM
  3. Windows XP Hibernating Problems
    By vicky_obee in forum Software & Software Development
    Last Post: 09-27-2005, 11:04 PM
  4. CarPC stopped hibernating!
    By Gobby in forum WinNT Based
    Last Post: 05-24-2005, 06:34 PM
  5. hibernating windows98
    By babas151 in forum Software & Software Development
    Last Post: 02-16-2004, 12:05 PM
