Results 1 to 10 of 20
Thread: WinXP - Speaker setup - what the fudge is it compared to on a PC?
    Variable Bitrate breaker021's Avatar
    Apr 2005
    Midtown Manhattan
    Hey all,
    My car has the stock 6 speaker setup that came from the factory. I am playing all of my music through the laptop and out of the stock speakers.
    I noticed on my laptop - which is windows xp - that when you go to control panel --> Sound and Audio Devices --> CLick on the Advanced button --> You can set your sound card to "output" to different types of speaker setups. This is what the screen looks like:
    My question to anyone is - Which of these settings will output the BEST (or correct) quality sound out of the stock speakers?
    Does this setting even matter? I've used the default setting this whole time (Desktop Stero Speakers) and the sound has been OK. When I get to see my car, I am going to play around with this setting and see what the difference in sound is - if any...
    Anyone have a clue though which speaker setup would yield the best sound?
    - sh00k
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by breaker021
    Hey all,
    - sh00k
    Either standard, or stereo headphones should be fine. The rest certainly shouldn't apply to your setup.
    Michael
    Apr 2005
    Midtown Manhattan
    Quote Originally Posted by Wiredwrx
    Michael
    I was thinking the same thing but what leads me to think differently is the fact that I have a (stock) 6-speaker system in my car. I would think the "stero" options would output the music in a 2-speaker format...
    I am GUESSING that if i set it to surround sound that the quality is going to be different - like a true surround sound system. I know when I listen to a music CD, i get the surround sound (sound moving from one speaker to another, etc) effect....
    - sh00k
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    - sh00k
    Here is the deal. Though you haven't stated how you connected everything to your carputer, it is impossible to say for certain, but, most likely, you have a wire going from your sound card to your HU. This wire is "stereo", meaning, it carries two seperate audio signals. This is stereo. The HU then takes the "stereo" audio of the two signals, and does with it what it wants, basically sending the signals to the speakers it wants.
    This is why what you set the computer to doesn't matter, as long as the sound card is sending out "stereo" audio. Also, that is the best the HU can accept, since the HU only has input for the 2 signals, and no more.
    If by chance you have a different setup, unless the soundcard is connected to the stereo speakers with more then 2 signals, changing it to 6 speakers, 8 speakrers, theater etc... will make no difference. Thos setting only matter if the Soundcard has connections for more then 2 speakers, and you are using more then 2 speakers, which you probably are not, because of the limitation of your HU.
    Also, sound moving from one speaker to another is not surrouond sound, that is stereo sound. Surround sound involves having subwoofers and tweeters in different locations, and specific sound signals being sent to individual speakers to give you the impression that you are "surrounded" by the sounds.
    Michael
    Apr 2005
    Midtown Manhattan
    You are the man, Michael. Thank you for the clarification - that makes perfect sense to me!
    I will continue to use the Desktop Stero setting since this is the only thing that is being outputted to my "stero" line.
    - sh00k
    Apr 2005
    Midtown Manhattan
    Hi again guys,
    just a follow up question. If I purchase a sound blaster audigy pcmcia card, and again, connect my laptop to this sound cards output port and have the other end plugged into my head unit, will it produce better sound? Or is the limitation still the fact that it's being outputted via stero?
    Thanks again,
    - sh00k
    Sep 2005
    UK
    that would replace the built in sound you have at the moment. It would likely give you a better sound quality, but would still be in stereo if your just connecting it to your hu.
    Not sure what u mean by "connect my laptop to this sound cards output port"?
    Apr 2005
    Midtown Manhattan
    The pcmcia sound card has an output for headphones. I would connect a stero cable to this port on the sound card and the other end would get plugged into my head unit.
    any clearer? lemme know!
    thanks,
    - sh00k
    Sep 2005
    UK
    no cable between the pcmcia card and laptop needed, the card would do all the sound processing itself, your original built in card would do nothing.
    headphone port does what it says on the box, allows you to plug headphones into it
    had a quick look at the audigy 2 zs. It has 2 ports, a line out and a headphone port, as well as a dock cable for surround sound. With your current set up you would connect the line out to the aux in on your hu.
    If you went around the hu and used a multi channel amp, you could utilise the surround sound capability
    Apr 2005
    Midtown Manhattan
    Currently, I have a stero cable - both ends are male stero jacks. I plug in the one end of the stero cable into the headphone jack of my laptop. then the other end of the stero cable i plug into the auxillary input on my head unit. this is how i output my mp3/movie sound to the speakers in my car.
    is there another way to output the sound that im not aware of?
    - sh00k
  1. How2 control CarPC from key fob....
    By NotchbackVW in forum Power Supplies
    Last Post: 09-21-2007, 06:27 PM
  2. For Sale for all you aussies. Complete mp3 car pc
    By Holden__V8 in forum Classified Archive
    Last Post: 04-09-2005, 06:30 AM
  3. WinXP drivers (especially sound) for Book PC i810
    By mykolJay in forum General Hardware Discussion
    Last Post: 07-19-2004, 03:35 PM
  4. weird speaker setup, how to connect?
    By turbochris in forum Car Audio
    Last Post: 07-13-2004, 05:51 PM
  5. Few questions about my current setup (xbox modded) migrate to PC...
    By Urinemachine in forum General Hardware Discussion
    Last Post: 11-13-2003, 06:24 PM
