Results 11 to 20 of 27
Thread: nLite v. TinyXP
  1. #11
    Maximum Bitrate DJiK's Avatar
    Apr 2005
    Los Angeles (Winnetka), CA
    Red, you've seriously got a 40MB functional OS?
    I should really look into nLite then.
    Have you considered booting from a flash memory instead of the HDD?
    For Sale: Carputer (CarPC) & RCA Y-Adapter
    Newsflash: Take a look at my unsold stuff above, thanks!
    Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
  2. #12
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    40mb is the memory footprint, not the hdd space it uses...
    Roy
    2005 Range Rover 4.4
  3. #13
    _
    Mar 2004
    Little Elm, Texas
    would booting from flash memory mean quicker boot up times?
    I'm sure that's a damn n00b question, but I'm a n00b on this relm of stuff.
    I've got a CF card slot on the board so I could use that for a solid state card for booting, right?
    Jan Bennett
  4. #14
    São Paulo, Brazil
    Nope... from what i've read and my tests most CF solutions are actually quite slower than an hd... SFiorito was testing a usb disk-on-chip solution that was to be quite fast...dunno...
    Roy
  5. #15
    Apr 2005
    Quote Originally Posted by RoyN
    Pardon the Noobish question, I tried to research but with no luck.
    What's a memory foot print and how is it calculated?
  6. #16
    Jan 2004
    NYC
    Quote Originally Posted by DJiK
    Im pretty sure it means the amount the RAM used when windows is loaded...
    for example the pic below shows the amount of ram being used in my MCE machine....
    The TinyXP build will have have a total of 40MB
  7. #17
    Apr 2005
    Thanks camsgs3, I was thinking along the same lines and in-fact did press Ctrl+Shift+Esc before posting.
    But I still don't get which memory is it referring to? Physical, Commit Charge, Kernel, or Page File?
  8. #18
    Nov 2005
    Quote Originally Posted by Red GTi VR6
    I'm going to go look up this 'bootvis' you mentioned to see what it is.
    regarding the bootvis - 30 seconds hu?
    I suppose if I've already got it lower than that (20-25 somewhere in there), then this wouldn't do me much good hu?
    Bootvis is a microsoft diagnostic tool. It has a function called optimize that will work on any speed machine. So if you running 20 secs startup now, it may be able to optimize it to 17 seconds. Run optimize three or four times.
  9. #19
    _
    Mar 2004
    Little Elm, Texas
    thanks for the info!
    Jan Bennett
  10. #20
    Variable Bitrate f1vlad's Avatar
    Feb 2006
    Nashua,NH
    Hey Red_GTi_VR6, what version of nLite are you using?
    f1vlad.com/subaru/sparow
    ■■■■■■■■■■■■■■■■■■■■■ 80% progress ¤ (sold)
  1. Safe nLite setting.ini
    By IntellaWorks in forum WinNT Based
    Last Post: 02-03-2010, 06:41 AM
  2. nLite XP ? and performance
    By NJ_Jackals in forum WinNT Based
    Last Post: 10-13-2008, 02:53 AM
  3. TinyXP bluetooth issue
    By inferno2469 in forum Operating System Optimization
    Last Post: 09-13-2006, 12:14 AM
  4. Nlite Build and SAPI
    By TheJack in forum WinNT Based
    Last Post: 04-21-2005, 06:51 PM
  5. Nlite to CF card?
    By SlashEMc2k in forum WinNT Based
    Last Post: 12-25-2004, 03:22 PM
