SqueezeBox and TinyXP REV4
I have finally gotten back to a project I started 6 months ago... Putting a SB2 in my car. I got the idea from link on this forum by a user who had done it. Anyway, I have a car pc running TinyXP on it. I want to connect the SB2 directly to the pc but right now they are both expecting to be plugged into switch or hub. TinyXP has IIS and other things removed from the system. So I guess my question is does anyone know a way around this?
I know I could nLite my own version but I am not savvy enough to know what I can keep and what I can remove. The PC is basically going to be running the SqeezeBox software only.
I think that your best bet would be to change to a different version of tiny xp that would have the services you are needing enabled. Retestrak.nl is currently down but when it comes back up it had a comparison of all of the versions and exactly what each one included. I believe that there are 6 different versions revsions 1-4, ultimate, and beast. Hopefully one of those versions has the services you would need.
Thanks, I didn't know that. I'll check it out.
If anyone has a copy of that comparison please post it.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
