Results 1 to 10 of 12
Thread: Horm confusion
    Nov 2005
    CT
    Horm confusion
    So I just enabled hibernate and put a resmany.dat file on the root of drive c: enabled ewf and restarted. But when the system hibernates it doesn't revert back to the original horm state. It remembers windows I've opened and programs I've started When I look at the modified date and time on the hiberfil.sys it hasn't changed.
    I have to be missing something dumb
    Please help
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    It won't change with the EWF enabled if I remember correctly. It's now going to be read only. Sounds like you need to disable ewf, redo your hibernation, then enable your ewf again. It sounds like you went into hibernation with programs open.
    Are you using the xpepm to hibernate?
    Tidder
    Try RevFE
    Sep 2003
    New Mexico, USA
    I'm not too sure as never ran into this problem exactly. You may want to PM SFiorito.
    Tidder
    Try RevFE
    Nov 2005
    CT
    Ok, this is for all the people who are dumb like me and need it spelled out for them. To use Horm when you enable hibernate do not set the computer to hibernate when the power button is pressed. Leave it as shutdown the computer. This solved my issue (so far )
    Sep 2003
    New Mexico, USA
    When I had mine set up in EWF, I just powered off, forget graceful shutdowns.
    Tidder
    Try RevFE
    Nov 2005
    CT
    Apparently from what I've read hibernate is not effected by EWF so when I set the computer to hibernate when the power button is pressed it would save the state. I fixed it by setting the power button to shutdown. Then after enabling EWF I did a manual hibernate. This set the state. After that the computer shuts down but when it restarts if comes out of the hibernated state.
    FLAC SFiorito's Avatar
    May 2004
    EWF and resmany.dat prevent the hibernation file from being reset so that when you boot it always resumes. If you run -commitanddisable -live after resuming from hibernation then you commit the reset flag in the hiberfil.sys file.
    Nov 2005
    CT
    Quote Originally Posted by SFiorito
    But even with those installed when I had my PC set to hibernate instead of shut down it would remember what changes I had made but the modified date on the hiberfil.sys stays the same. Once I set it to shut down it resumes from the hibernated state on bootup but the changes are lost. My resmany.dat is a 0kb file, should it have any data in it?
    Sep 2003
    New Mexico, USA
    No, no data should be in it, I think it just checks to see if the file exists. I don't think it uses the contents for anything at all.
    Tidder
    Try RevFE
    May 2004
    If you rehibernate it'll use that new hibernation point. When you hibernate, I'm pretty sure it bypasses any filter drivers installed such as EWF. It was working as designed....
  1. Confusion Says
    By Enforcer in forum Off Topic
    Last Post: 01-30-2007, 02:22 PM
  2. HORM and Harddisk ?
    By Konrad in forum WinNT Based
    Last Post: 02-21-2006, 01:36 AM
  3. Minlogon, EWF and HORM - Problem Fuzzy screen menus after HORM hibernate
    By ruairi in forum Operating System Optimization
    Last Post: 11-30-2005, 08:51 AM
  4. HORM and power cutoff
    Last Post: 08-04-2005, 08:40 AM
  5. using EWF + HORM
    By BOND007BE in forum WinNT Based
    Last Post: 03-29-2005, 03:41 AM
