Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: 2Fast XP - newer distro
  1. #11
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    Links to torrent have died anyway
  2. #12
    Newbie F3rr3r's Avatar
    Mar 2005
    Baltimore, MD
    ok here's the deal. I have an Apacer thumb drive which is pretty fast at around 200X speed here's a picture http://us.st11.yimg.com/us.st.yimg.c..._1906_21188687 so I'm sure the results will vary depending on other peoples thumb drive speeds. It is about 5 secounds faster on startup than just using my 4800 rpm hard drive. Explorer windows pop up instantly and files deffinately appear to be accessed much faster than the traditional HD. I haven't attempted EWF yet and I won't be able for a while either because after I tested the OS. I tried to plug it into a different computer to browse the thumb drive and it screwed up the bootabillity of the thumbdrive. maybe the MBR? I'm not sure but keep in mind if you do install to a thumb drive DONT ACCESS IT FROM ANOTHER COMPUTER RUNNING WINDOWS. I'm thinking external HD is probably going to be the better solution anyways because the thumbdrive is constantly being accessed (solid yellow light on the stick) that can't be good for it. I know ewf prevents writes but I'm not sure how many reads a thumb drive can take. what do you guys think? any other questions by the way?
    My Build
    Progress: 80%
  3. #13
    Mar 2005
    Baltimore, MD
    link
    hhmmm...... not sure if this is going to be ok but...
    xBrady:
    Sorry, it's not ok.
    My Build
    Progress: 80%
  4. #14
    Variable Bitrate proph's Avatar
    Aug 2005
    Little Elm, Texas
    Any instructions for this?
  5. #15
    Mar 2005
    Baltimore, MD
    @proph
    put in your thumbdrive, turn on your computer, and install the hacked windows cd like you normally would install windows except that it shows your thumbdrive as an HD to install to.
    My Build
    Progress: 80%
  1. How to get XP installed?
    By Grrrmachine in forum WinNT Based
    Last Post: 11-15-2005, 02:20 AM
  2. Help Neede @ My Life End With Cf & Xp
    By scooby8272 in forum WinNT Based
    Last Post: 11-12-2005, 09:59 AM
  3. Run WinCE & XP together
    By ShawJohn in forum Software & Software Development
    Last Post: 11-07-2005, 05:09 PM
  4. Difference between Windows XP Home & XP Pro?
    By grandamp3 in forum Off Topic
    Last Post: 02-21-2003, 05:07 PM
