Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: whats your fastest boot time on a pIII 700mhz-1ghz
  1. #21
    Mar 2007
    Fujitsu Tablet 600 (P3-500MHz) with 256MB RAM. From hitting power button to full Windows XP desktop with hourglass disappears is 38 seconds. Shut down takes 5 seconds from hitting the power button. Hibernate takes 9 seconds.
    The BIOS loading takes a while, almost 20 seconds so Windows portion loads pretty quick given the speed and RAM of the tablet. Unfortunately Centrafuse takes about 20 seconds to start itself.
  2. #22
    Oct 2004
    Sydney, Australia
    wow so high times, ive done nothing to tweak my system im getting 28 second times from ignition on to front end loaded. VIA 1.2gh 7200rpm 512ram winxp pro media engine.
    Im sure I could get that under 20 seconds if i get my mate to tweak it.
    Continued Worklog... Upgrades in progress:
    *15.4" WXGA LED backlight touchscreen upgrade
    *Custom fiberglass dash bezel
  3. #23
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    I was getting 10 second boots with my XP image running in vmware. Now running on my 1ghz via with all my apps I am getting around 20 second cold boots. I also used nlite to make my XP image and I am booting the whole system from a 1 gig SanDisk compact flash drive. Im runng EWF and some other XP embedded tools which makes my setup *very* similar to a full XPE build.
  4. #24
    Aug 2006
    Portland, OR
    still needing a monitor but I've gotten my p-3 600mhz to about 45 seconds from cold into whatever front end i choose, and down to 29 seconds from hibernation.
  5. #25
    May 2007
    disabling any graphics in the load option usually helps too ... things like bios logo's, and you can even disable the whole windows XP load logo from the registry. I need to repull up whihc one exactly takes care of that ... but I know its doable.
  6. #26
    Newbie OptimusPrime's Avatar
    May 2007
    S.Wales, UK
    Quote Originally Posted by dj55b View Post
    If you want to disable the Windows XP loading screen, just add this to the last line in your boot.ini file.
    /noguiboot
    e.g. My last line reads
    Code:
    multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect /noguiboot
    Only saves about half a second, but it all adds up
    HTH
    Daz
  7. #27
    May 2007
    Portland, OR
    P3 1000mhz, 440megs of PC133, XP Pro Corporate, some services disabled. PSU is an antec 200W POS.
    Cold boot: 29 sec to fully operational
    Resume from Hibernate: 14 sec to fully operational.
  8. #28
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    7 seconds from standby to playing music in road runner. (includes my 3 second startup delay)
    P4 2.4ghz, 1gb ram, Dell SX260, XP Media Center (standard install), Carnetix P2140
    New Age Garmin - Skin for RR
  9. #29
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by ThunderStick View Post
    Quote Originally Posted by title
    What's your fastest boot time on a pIII 700mhz-1ghz?
    1.9in x 2.9in -- 47mm x 73mm
  1. Oh where have all the Shutdown Controllers gone (and boot time)?
    By SuperAJ in forum General Hardware Discussion
    Last Post: 05-21-2005, 10:57 PM
  2. Reducing my boot time bit by bit.
    By themurph1018 in forum General Hardware Discussion
    Last Post: 11-16-2004, 07:39 AM
  3. Does using shutdown controller add to boot time?
    By nxt125 in forum Power Supplies
    Last Post: 08-07-2002, 01:38 PM
  4. Fast boot time 350mb ide flash disks!
    By Mp3 V in forum Classified Archive
    Last Post: 02-15-2002, 07:58 PM
  5. Fastest DOS boot possible
    By alexchannell in forum Software & Software Development
    Last Post: 12-27-2001, 09:46 AM
