have you read Microsoft's documentation on how to deploy to a CF card? Since your CF slot is on IDE2 have you configured your BIOS to boot from that channel? What's your boot.ini file point to?
Hey guys,
I did search but got mixed results that I have a hard time deciphering so I am going to post this here...
Here's what I have done so far:
Installed XP Professional on my target system (a Single Board Computer with a built in CF slot) onto a standard laptop drive, set up all the drivers, etc... then used the Target analyzer program to create a file that I imported into target designer.
I did what I needed to do there, built the image and copied it onto a CF card.
Now, the CF card comes up as IDE2 (Secondary Master) on the motherboard, but I cannot get it to boot.
I have set up the CF card as a NTFS drive, is there something else I need to do to make it bootable?
Thanks!
Did you see this? http://mason.gmu.edu/~sfiorito/eXPinstall.htm
Be very patient... first time booting off the CF card after installing XP will take awhile.
After a few starts and restarts, it gets faster. With EWF and MiniLogon (only after you 'install' your programs), it'll be even quicker.
I just wanted to get past the "no boot device found" error from the BIOS on startup![]()
changed my boot.ini file to look for Windows on disk 2 but no go![]()
I just formatted it FAT32 in Windows then converted it to NTFS using the convert util in a command dialog box.
The problem is that I don't have an IDE-cf adaptor, and while the CF slot is on the IDE bus on my target system, I do not have a floppy drive for it.
And yes, the card is "Active"
What kind of board do you have, and can you verify it supports booting off CF? I read somewhere certain [VIA] boards do not support booting from CF despite having a CF slot integrated to the IDE bus.
You can probably find a CF-IDE adapter locally for about $10. I know a computer store nearby that sells one :-)
