Results 1 to 5 of 5
Thread: Big Help Installing Windows
    Constant Bitrate ramez75's Avatar
    Dec 2006
    Nazareth PA
    I formatted the CarPC to install my own windows (I have windows XP Media Center) well after screwing with the partitioning and formatting the harddrive I was able to install my copy of windows. But now I have no Standby option, hibernate i cant even shut down, well i can i have to like pull the power plug each time i need to shut down. Also my touch screen doesnt work now i have the driver but dunno maybe doing something wrong. I lost the volume. So basically i shouldnt have formatted the carPC but its done now.
    Guys any suggestions or inputs or where can i start
    Mar 2006
    Colorado, but Canadian!
    Just a wild guess but you didn't install any drivers. Naughty naughty.
    The touchscreen needs drivers. Download and install Touch Kit. Do a google for "touchkit drivers" and you'll find a ton of sites.
    Just because it works doesn't mean it is working properly. The drivers that it is using now, are all the unoptimized bundled drivers. For hibernate and standby you need to install video drivers. Also enable hibernation by going to system prperties --> hibernation and enabling the boxes.
    You really should know this if you are going to do a CarPC because you are going to have one hell of a headache if you don't even know rudimentary xp things.
    1.9in x 2.9in -- 47mm x 73mm
    Buy now in the Store
    Dec 2006
    Nazareth PA
    Oh no I am aware of the drive and i made sure i backed all the drivers to my laptop before formatting but i installed the touch screen driver and nothing happened and now i realized that i have 2 more touch kit driver thing so i will try those too. About the standby and hib i went to the system and i dun even have the option. When u click on start and shut down i have only Restart and shutoff.
    I will install the video drivers and see if i get the options of standby and hib
    May 2006
    Calgary, Alberta
    Download the updates from
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    2005 Honda Civic
    Maximum Bitrate tn6478's Avatar
    Jun 2006
    Houston, TX
    Are u using a legit version of windows. If so that may be your problem
  1. Windows Vista
    By thanatos106 in forum Software & Software Development
    Last Post: 06-28-2006, 10:56 AM
  2. Linux or Window$$
    By Psychobiker in forum General MP3Car Discussion
    Last Post: 02-17-2006, 08:45 AM
  3. Installing windows
    By 91yjeeper in forum Newbie
    Last Post: 09-15-2004, 09:39 PM
  4. problem installing windows xp via bootCD and opus
    By BMW5CAR in forum Power Supplies
    Last Post: 09-11-2004, 12:16 PM
  5. Running windows with no monitor?
    By BLACKOUT in forum General Hardware Discussion
    Last Post: 03-14-2001, 10:56 AM
